4x4 help!
Old Oct 14, 2009 | 07:46 PM
dhvaughan's Avatar
dhvaughan
welcome to DF.
you probably already know this, but the safest way to troubleshoot 4wd problems is to put the truck up on 4 jack stands. then you can shift away, running or not, and rotate the driveline as needed.
you do have the same gear ratio in the front and back don't you ? if you're not sure, test it to be sure.
Old Oct 15, 2009 | 09:44 AM
Moparfanatic91's Avatar
Moparfanatic91
Ok so I know I wasn't in nuetral cause when I tried it stationary I got minimal tire movement when giving it a good amount of gas(unless that's somehow in nuetral). So if it is the transfer case how can I check that and how do I check if the front rear axle ratios are the same??
Old Oct 15, 2009 | 09:52 AM
Moparfanatic91
Oh And I'm new to any and all techniques the more info and tricks you cam dish out the better it is I'm only 18 so I'm no expert on these things lol
Old Oct 15, 2009 | 09:57 AM
Sheriff420's Avatar
Sheriff420
Originally Posted by Miami_Son
You are so wrong. These trucks were designed to shift-on-the-fly into high range 4x4 and back to 2x4 below 55mph. You only need to slow to shift into low range 4x4 and even then you can still do so up to about 15mph.
you forgot to mention not to pause in neutral when you shift to 4lo, unless you like the sound of gear clash.
i just let off the gas when i shift to 4hi, then i give the shifter a wiggle to make sure its all the way back and keep on going.
Old Oct 15, 2009 | 10:20 AM
95RAM360's Avatar
95RAM360
see we learn something new everyday
Old Oct 15, 2009 | 11:18 AM
Aubrey's Avatar
Aubrey
I was first thinking the t-case wasn't engaging but now it sure does sound like that new rearend is a different gear.
Old Oct 15, 2009 | 11:35 AM
offroadjosh's Avatar
offroadjosh
Did you say you can shift into 4lo while moving 15mph? I have always came to about 1mph-2mph slipped it in Neutral and then put it in 4lo. I thought you must be going slow and in Neutral??
Josh
Old Oct 15, 2009 | 11:44 AM
Miami_Son's Avatar
Miami_Son
Nope. Read Sheriff's last post. If you stop in neutral the gears will freespin and then grind when you do shift into gear. You should never pause in neutral unless that is where you want it to be.
Old Oct 15, 2009 | 12:14 PM
offroadjosh
Naw i was talking about the tranny(putting that in neutral.) Then going from 4hi directly to 4lo. I can do that while moving?? I can see doing it 1-2mph but any fast im worried i would blow something up.
Old Oct 15, 2009 | 12:17 PM
Miami_Son's Avatar
Miami_Son
You can shift the transfer case directly into/out of 4 high at any speed below 55mph. You don't need to shift the tranny into neutral. That's what shift-on-the-fly means.
