T-stat gasket
Old Oct 16, 2009 | 11:22 AM
mugsaway's Avatar
mugsaway
Default T-stat gasket
I went to the DIY thread (Ram 2nd Gen DIY information and links) and found the link for replacing the T-stat (#26). I figured I could use this as a base for just to replace my gasket.
Just my luck the pictures are not available. I really need this as I am not mechanically inclined. Just reading the steps does no justice for me. Is it possible to get these pics for reference?
Old Oct 16, 2009 | 11:28 AM
Sheriff420's Avatar
Sheriff420
https://dodgeforum.com/forum/2nd-gen...t-install.html
those pictures work.
Old Oct 16, 2009 | 11:33 AM
mugsaway's Avatar
mugsaway
Thanks Sheriff, the second time you have pointed me in the right direction......
Old Oct 16, 2009 | 01:43 PM
Sheriff420's Avatar
Sheriff420
your welcome. i was just informed that the DIY you looked at is for a CTD and not the v8. so which one do you have?
if you click the link at the top of any page that says "User CP" then click "edit details" in the top left corner of that page you can put info on your truck in there.
or you can click the link in the User CP that says "edit signature" and put the truck info there.
Old Oct 16, 2009 | 01:51 PM
BlueBeast2's Avatar
BlueBeast2
Why would you go that far and not replace the t-stat?
Old Oct 16, 2009 | 02:14 PM
wjxavier's Avatar
wjxavier
yea...as the above suggested, you might as well replace the thermostat while you're there. its a common practice and will save you trouble later on down the road if it happens to crap out.
Old Oct 16, 2009 | 03:00 PM
Laramie1997's Avatar
Laramie1997
Oh lookie! My thread. How nice.
I need to talk to Miami and see if I can talk him into replacing it in the DIY.
Old Oct 16, 2009 | 03:08 PM
mugsaway's Avatar
mugsaway
Thanks. I entered the info.
I figured I would change the stat also, just talked about the gasket. Can I just use the gasket or do I need to buy some of the silicone(?) with it?
Old Oct 16, 2009 | 03:11 PM
BlueBeast2's Avatar
BlueBeast2
Gasket should be fine
Old Oct 16, 2009 | 03:43 PM
95RAM360's Avatar
95RAM360
i would put a small small bead about 1/4 in thick around the gasket, just so when it goes bad again it has reienforcment
