Oil pan removal question
Old Jan 29, 2009 | 02:09 PM
EvanMacaluso's Avatar
EvanMacaluso
Default Oil pan removal question
I have a 98, 1500, 4x4, 5.9 gas. I recently replaced the timing chain and when I pulled the cover I ripped the oil pan gasket. I need to replace the entire gasket as it is too shot to RTV. Haynes says I have to raise the motor to get the oil pan down??? Do I need a hoist or can I jack the motor up from below? Also if I need a hoist can someone please tell me exactly where I should attatch the hoist to the block front and back. There are no empty holes I can see and I would prefer not to remove all of the accesory bracket if I don't have to. Thank you in advance for you assistance.
Evan
Old Feb 1, 2009 | 06:12 PM
Formosa Joe's Avatar
Formosa Joe
Evan
First you need to remove the fan shroud, loose the motor mounts, disengage the auto shifter and possibly remove the y-pipe from the exhaust. Then use a wood block on your jack and you can jack the motor at the balancer.
Hope this helps
Joe
Old Feb 16, 2009 | 03:08 PM
calumetbud's Avatar
calumetbud
when I replaced my oil pan I just took the starter off and the pan came right off
Old Feb 17, 2009 | 04:21 PM
spiral72's Avatar
spiral72
I agree, I've had the pan off four times with the motor in the truck..... it's a long story.
Granted, it's tight but the pan will come off without lifting the motor.
