Spark Knock?
Old Oct 16, 2009 | 07:09 PM
okcowgirl97's Avatar
okcowgirl97
Default Spark Knock?
I have a 2000 with a 5.9L in it. I get a spark knock during acceleration but not during general running. I have replaced the timing chain, distributor cap and rotor bug which has helped improve it a little bit. Picked the brain of a dodge mechanic and he says to retard my timing a little bit by setting distributor back a tooth or two. My problem is that I cannot figure out how to get to the bolt to loosen the distributor to retard it a bit. Any ideas/suggestions out there?
Old Oct 16, 2009 | 07:23 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Do NOT do what the mechanic suggested! Your problem is the plenum gasket is blown, the cat is gone or going as is the precat o2 sensor. Do a search here for "plenum" and you will find all the info you need about the topic.
Old Oct 16, 2009 | 07:46 PM
halfamil's Avatar
halfamil
okcowgirl97, welcme to to forum.
