14x3 question
Old Oct 17, 2009 | 03:46 PM
360mag45's Avatar
360mag45
Default 14x3 question
i know there are a **** load of these threads but the search is being gay and i can't find them.So just bought a holley 14x3 air cleaner i have made the S screw but i still can't get it to fit im stuck. How did you guys get yours to fit?
Old Oct 17, 2009 | 04:47 PM
Hammer Down's Avatar
Hammer Down
How is it not fitting? Keep in mind that you will need a throttle body spacer under the air cleaner to clear the throttl linkage and other things.
Old Oct 17, 2009 | 04:53 PM
360mag45's Avatar
360mag45
just trying to get it over the s bolt or trying to get the s bolt in with mine it dose fit i checked it all out and it fits no problem its just geting it fastend down with the s bolt
Old Oct 17, 2009 | 04:58 PM
Hammer Down
I set the base pan and filter on the TB, then put the S bolt in. Make sure you used 1/4 inch threaded rod for the S bolt. Also, mine is just barely long enough to accept the wing nut, so clearence is less of an issue.
Old Oct 17, 2009 | 05:04 PM
360mag45's Avatar
360mag45
ok i well give that a try
Old Oct 17, 2009 | 07:54 PM
360mag45's Avatar
360mag45
ok i need the 1/2" spacer and i well be set thancks hammer for all the help
Old Oct 18, 2009 | 10:22 PM
Hammer Down
Anytime, brother!
