Dodge Ram Engine and transmission moves forward when throttled in gear
Old Oct 17, 2009 | 05:55 PM
KongRam's Avatar
KongRam
Default Dodge Ram Engine and transmission moves forward when throttled in gear
Hello, I am new to Dodgeforum. I have a question that I hope someone can provide an answer to. I have a 1998 Dodge Ram 1500 with a 360 auto quad cab 4x4. It has a 3" body lift and a 3" suspension lift on 35" tires. I made the suspension lift myself by making spring spacers from cast iron pipe in front and added 3" blocks to the rear with grade 8 u-bolts that were made from stock. I have noticed that when I throttle the engine that it moves forward and clunks real hard. It feels like a broken tranamission mount but it is good. I had someone else help me and watched the motor mounts as they pressed the gas pedal in gear. The engine jumped forward at the mounts. It is worse when I am towing. I thought that I would try to tighten the mounts more, but that didnt help. I didnt do anything to the pinion angle and wonder if that would be the case, but am reluctant.
Old Oct 17, 2009 | 05:57 PM
95RAM360's Avatar
95RAM360
are any of the parts you put on moving around?
Old Oct 17, 2009 | 07:24 PM
Hammer Down's Avatar
Hammer Down
Checked the engine mounts?
Old Oct 17, 2009 | 07:27 PM
Sheriff420's Avatar
Sheriff420
the rubber on the transmission mount should be pretty firm, when it gets soft then you will see a lot of movement under load.
it sounds to me like your motor mount bushings are just wore out. do they have a film of any kind of fluid on them?
did it do it before the lift? or before doing anything to the truck?
Old Oct 17, 2009 | 08:07 PM
WaynesWorld's Avatar
WaynesWorld
time to replace the motor mounts
Old Oct 17, 2009 | 08:24 PM
95RAM360's Avatar
95RAM360
Since we're on topic of mounts, how hard is it to change the tranny mount? can i just get some jacks, hold up the tranny,and take it right out?
Also motor mounts are gunna run about 55-70 bucks each ( Auto Zone price) just so you know
Old Oct 17, 2009 | 08:59 PM
rgp944's Avatar
rgp944
replace your motor mounts. make sure they ate urethane and not rubber.
Old Oct 18, 2009 | 02:54 AM
Sheriff420's Avatar
Sheriff420
correct. super easy.
you should have seen the one on my camaro when i got it. that mount was about the same texture as a gummy bear and when i gassed it from a stop the transmission would slap the floorboard.
Old Oct 18, 2009 | 07:10 AM
95RAM360's Avatar
95RAM360
mines very chewed up, doesnt even have a partof the corner, and chunks missing everywhere, but still it shifts nice and smooth...but i want to replace it anyways (35 bucks, why not.)
Old Oct 18, 2009 | 09:51 AM
KongRam's Avatar
KongRam
I replaced the mounts about 4 months ago. This has been going on for 6 months. It has gotten worse since I replaced the mounts. I replaced the rear brakes when I replaced the mounts and noticed it even more.
