In-Expensive Lift
Old Oct 17, 2009 | 11:31 PM
big.red.ram's Avatar
big.red.ram
i think it looks alot better with white letter out. tires look to plain with the white letters in
Old Oct 18, 2009 | 02:43 AM
Sheriff420's Avatar
Sheriff420
Originally Posted by 95RAM360
As for the front. Ive seen some lift ics where the front shocks just have a metal spacer at the top of the spring. Now is this something i could buy at a local Auto parts store? or are those spacers special order?
http://www.hellbentsteel.com/catalog...it/category/4/
i just put that leveling kit on mine. if you do that and either get add a leafs or bigger blocks then it would be a cheaper way to lift. i'm probably going to go a couple inches higher in the rear on mine and do the same thing you're wanting to do. i didn't so much want to level my truck as lift it.
Originally Posted by nathangfnd
But here is an epic fail at using coil spring spacers
where?
Originally Posted by estech2
Be careful, I bought the cheap lift blocks from AZ, they were cast aluminum and lasted about 6 months and one day I floored it to pull into traffic and shattered both of them, spum my rear axel 45 degrees and snapped my rear U-joint. luckily I was not moving very fast or it could have killed me. There was not much holding the axel to my truck. I ended up pulling the DS and limpimg home in 4hi. The good ones are not much more. go to Fat Bobs Garage. com, that is where I got my 2" level kit and 1" rear blockes and Ubolts. Trust me on this one, cheap is NOT better when it come to suspension. That is a DAMN fine Dodge Big Red!!!!!
i sure hope that company paid for the repairs.
Not to argue but I was able to install my 2" spacers with out a compressor, But I practially had to completely pull the front axel, only took a couple of hours, 3 tops.
i had to take my track bar, stabilizer links and passenger tie rod end off and drop the axle all the way down on the two floor jacks i was using and still had to compress the springs to get them under my 2.5" spacers.
Old Oct 18, 2009 | 06:52 AM
95RAM360's Avatar
95RAM360
thx Sheriff, i hope i wont have to take apart the trac bar etc. hopefully i can get it compressed.
and ordering them today
Old Oct 18, 2009 | 06:57 AM
Laramie1997's Avatar
Laramie1997
If you have an oreily's around you, they consider a spring compressor to be a specialty tool, and they will loan it out to ya fairly cheap. <$20.00
Old Oct 18, 2009 | 07:08 AM
95RAM360's Avatar
95RAM360
ive never heard of O'reilys...and thats a good price since i have to rent one from AZ and its 99.00, but i get it back when i return it so, it doesnt really matter
Old Oct 18, 2009 | 07:09 AM
Laramie1997
Either out West, or East then. O'rielys is mainly a midwest thing.
Old Oct 18, 2009 | 07:33 AM
Sheriff420's Avatar
Sheriff420
we just got an oreilleys in my town and i hadn't heard of them until i saw it on here.
the spring compressor was 48.99 there and the locks on it don't fit over my coils so it was a little dangerous.
i might have stiff springs because i had to drop the axle down quite a bit to get them back in there and there are a few people that didn't have to do that. to get the axle to drop down far enough you have to take the end of the track bar off that is under the passenger coil.
to get my track bar to line back up to get the bolt through it i had to use a come along hooked under the passenger coil and on the frames cross member because the truck shifted toward the drivers side about an inch when i put the weight back on the springs.
Old Oct 18, 2009 | 12:33 PM
004x41500's Avatar
004x41500
i didnt use one for my 2.5" i just cocked the axle to get the side i wanted in, and i didnt have to undo my track bar either.
when i put my passanger side spacer in, i jacked the drivers side of the axle up, and made for the clearance to get what i needed. though i still had to compress the spring, but it wasntenough to have to use a spring compressor, i was able to compress it enough by hand to give clearance that i needed.
Old Oct 18, 2009 | 02:54 PM
Weldor's Avatar
Weldor
I never knew the hulk drove a dodge ram...awesome!
Old Oct 18, 2009 | 02:56 PM
004x41500's Avatar
004x41500
well you know, i only drive the BEST
now to get the truck painted green...
haha, lmfao.
i only had to compress it about 1/4" to get it to go in
