5.2 use any 5.9 part?
Old Oct 18, 2009 | 03:41 PM
awery19's Avatar
awery19
Default 5.2 use any 5.9 part?
i was wondering if i could use any parts off the 360 to make more horse or torque on my 318.
Old Oct 18, 2009 | 03:54 PM
joekool4's Avatar
joekool4
actually i was reading in the owners manual that the 360 only has more torque and barely any more horse because of the compression ratio, i think the 318 is something like 8.9:1 and the 360 is like 8.0:1 but maybe the headers might be swappable and the intake
Old Oct 18, 2009 | 04:05 PM
xskylinedx's Avatar
xskylinedx
They are both about 9:1 compression depending on where you look up the info.
http://dodgeram.org/tech/gas/specs/5_2v8.htm
http://dodgeram.org/tech/gas/specs/5_9v8.htm
Old Oct 18, 2009 | 04:34 PM
Sheriff420's Avatar
Sheriff420
i was wondering about the throttle body myself. doesn't the 360 have bigger bores in it?
Old Oct 18, 2009 | 06:06 PM
xskylinedx's Avatar
xskylinedx
I'm pretty sure they are both a 50mm tapered bore
Old Oct 18, 2009 | 06:21 PM
dodgeram07's Avatar
dodgeram07
correct
Old Oct 18, 2009 | 06:41 PM
BlueBeast2's Avatar
BlueBeast2
Its the same engine. The crank and maybe a couple other stupid little things are different. Most of the parts are the same and won't make a bit of difference
Old Oct 18, 2009 | 07:31 PM
004x41500's Avatar
004x41500
externally they are the same, internally they are not. the 5.9 has a slightly bigger bore, and slightly longer stroke. if the bores were the same, you still would have a 5.2
Old Oct 18, 2009 | 08:48 PM
crazzywolfie's Avatar
crazzywolfie
on the older dodge 318's the bore and stroke is 3.91x3.31 inches and on the 360's its 4.00x3.58inches. i don't think any of the parts off a 360 would give your 318 any more power.
Old Oct 18, 2009 | 09:03 PM
xskylinedx's Avatar
xskylinedx
the 5.9 is externally balanced and the 5.2 is internally balanced.
