Water Pump bolt and Flex plate install questions
Old Oct 20, 2009 | 10:45 AM
BlueBeast2's Avatar
BlueBeast2
Default Water Pump bolt and Flex plate install questions
I know broad area.
Can someone tell me where the torx bolt goes on the water pump. A pic if someone has one would be great.
Does it matter how the flex plate goes back on? Its there any kinda timing associated with it? I marked it but after cleaning the engine I doubt the marks are gonna be there
Old Oct 20, 2009 | 09:14 PM
dhvaughan's Avatar
dhvaughan
this is just a feeble minded guess, but i think it was around top center. check the lengths of the bolt vs the thickness of the casting. if the lengths are the same, then it won't really matter.
no timing associated with flex plate.
Old Oct 20, 2009 | 09:47 PM
BlueBeast2's Avatar
BlueBeast2
Thanks. I had pc look at his and he said it wasn't any of the top ones. They are all the same size. I just wanna make sure its not different so the belt or something don't hit it
Old Oct 21, 2009 | 09:47 AM
BlueBeast2's Avatar
BlueBeast2
I found it. after looking at my pics more it is the top center. thanks dh
Old Oct 21, 2009 | 11:44 AM
pcfixerpro's Avatar
pcfixerpro
I looked yesterday but all of mine are regular head bolts that I can tell from standing outside the engine bay. Haha, just be happy you got your pic's of the engine / trans bracket mounts you wanted after I hit my head crawling back out from underneath of the truck.
Old Oct 21, 2009 | 11:55 AM
BlueBeast2's Avatar
BlueBeast2
That still has me confused. I was just looking at it and the don't bolt up right. Unless the other mounts gotta be there first
