Bumper Sag
Does anybody know how to fix the front bumper from sagging? There's lots of bolts on it, and I don't want to make it worse by messing with the wrong bolts. If you know of any thread that has info on this please let me know. Thanks.
IIRC, the bolts on the two center support brackets are what need adjusting, where they connect to the frame.
Look at the "Merry Christmas" thread, at the 2001 service manual (its an Adobe PDF). 2001s (non-Sport models) have the same bumper/brackets/etc. as your 1996.
I have a tiny gap myself, from when I replaced my front bumper (accident). I just don't think its worth it to get in there, under there, and loosen/remove bolts, try to adjust the big freak'n heavy bumper by myself, while tightening bolts. I need four arms.
But if you have the will and perhaps a second person to assist you, go for it.
easy fix. spray all those bolts with pb-blaster or wd40 and let it soak. i think its a 18mm deep well with a good heavy breaker bar. those bolts are real tight. loosen them all up so you can shift everything around easily. each bolt is slotted with a couple of inches of movement. don't worry about messing it up, you'll be fine. i used 2 floor jacks to hold the bumper up on each side without busting a gut. positioned it level and even, then snugged each bolt, then tighten the **** out of them. you can do the rear also.
