Need help regarding my new tires
Hello all
Just got new 35X12.5X16 MT Tires on 16X10 Rims. Tire look great on my 1996 Dodge Ram 1500 4X4. It has a 3 inch body lift, complete new front end and edlebrock shocs. My question is, can the ABS or speedometer be adjusted to reflect the new tires. Was told by my Dodge dealer that they cannot do a 1996 with there equipment. Read that adjusting the ABS will adjust speed and the shift points with the new tire size when it is entered ... need to know if anyone knows how this can be done
Thanks
Thanks
Yes, you can, cheaply, too. There is a gear on the end of the speed sensor in your transmission you need to change. I'll see if I can find where the DIY is for this.
EDIT:
http://www.rm-indy.com/speedo_correction.htm
EDIT:
Ok ... that was interesting, didn"t know of that gear, but they way I understand your reply is if you change the gear ratio in the front and rear from the stock 3.55 and you have a 32 tooth gear, you would change this gear to match the gear ratio .. but I changed my tires to 315/70R16 or 35X12.5X16 and left the gears at the stock 3.55.
Increasing my tire size makes my gear ratio higher. The transmission shifts based on engine RPM and throttle. The tire difference makes you go faster at the same given RPM and throttle. Adjusting the speedometer will not do that much other then it might save you getting a ticket. The tranny will still run hot because of the shift delay.
I am pretty sure to help this shifting and your speedometer, you shoud be adjusting you ABS setting to reflect the tire size you have and forget about the speedometer calibration. The only other things you can do is, change the front and rear gears and install lower ratio gears at about a thousand bucks per axle, or put a transmission cooler on ....which I would not do because the dodge's already have a problem in the winter with the transmission not warming up fast enough and whining. I was hoping someone new a way of adjusting the shift points so the tranny won't overheat with the larger tires and be toast. I know the newer dodge rams can be reprogrammed but can't understand way the dealer can't do a 96 ram. Any help would be greatly appreciated ....thanks for reading this.
Trending Topics
OBD1 readers are for 1995 and older, OBD2 is for the 1996 and newer vehicles, I have that but I do not have any error codes to worry about. Just trying to figure out how to reprogram shift points in the ECU ... I am confident that its in the ABS set-up that you have to change tire dimensions to get the ECU to recalculate shift points.
Thanks though for the imput
BTW my jeep was a 5 speed stick and even with no shiftpoints to worry about 5th gear was practically usless to me and I wasted more gas alway flooring it to try and get going.It was a real dog ...and this was only with 32 inch tires and stock 4.10 gears on a 145horse 4 banger....3.55 gears and 35s with a v8 is a pretty good comparision I think. difference was day and night with the gears...way BETTER on gas and way more pickup.
