Valve Cover Gaskets
Old Oct 21, 2009 | 11:38 AM
95RAM360's Avatar
95RAM360
Default Valve Cover Gaskets
So my valve cover gaskets are getting a bit moist around the edges (still have perfect oil level) So i want to replace the valvecover gaskets. Ive done many, but not on a V8 where theres 2. now they look pretty easy, but are there any kinks that anyone runs into? is it a breeze?
Old Oct 21, 2009 | 12:20 PM
Hahns5.2's Avatar
Hahns5.2
It's very easy, the gaskets should be rubber so no need for RTV or anything. Remove the valve covers, make sure the mating surfaces are decently clean and put the new gaskets on, I torqued mine all evenly to 5 ft/lbs and no leaks.
Old Oct 21, 2009 | 01:08 PM
AlabamaRam95's Avatar
AlabamaRam95
itll make you feel like a genius.
very easy to do.
Old Oct 21, 2009 | 01:33 PM
dodgeram07's Avatar
dodgeram07
is it a breeze..... i also like to check if the valve cover is blent(like the person before me over tighten) just sit it on the table or sum thing flat
also felpro gasket are great!!..but a little on the high side$$$ but worth the money
Old Oct 21, 2009 | 01:36 PM
95RAM360's Avatar
95RAM360
i got the fel-pro, but i made a new thread (shouldve just used this one) with a problem i found, please check it out.
Old Oct 21, 2009 | 08:11 PM
wjxavier's Avatar
wjxavier
you could always replace the gaskets regardless, but if you're not too worried about it, first i would check to make sure the valve cover bolts are not loosening. they tend to do that after a while. i've had valve cover bolts come loose to the point where i could spin it with my fingers. just retorque them, clean up the oil seepage and see where it goes from there
Old Oct 21, 2009 | 08:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
LOL, this guy is too much.
Old Oct 21, 2009 | 08:20 PM
95RAM360's Avatar
95RAM360
i read in the haynes repair manual that they should be re-torqued every oil change
Old Oct 22, 2009 | 04:43 AM
wjxavier's Avatar
wjxavier
well, if you've been torquing them, and they're still leaking, then yea...replace them haha
Old Oct 22, 2009 | 07:57 AM
95RAM360's Avatar
95RAM360
i havent re-torqued them at all since ive had the truck (4 oil changes)
but i got one side done, and its nice and dry now. im taking on the other side today, an ordering my hughes plenum plate and intake gasket kit
