Uh Oh...Warped Head?
Old Oct 21, 2009 | 05:36 PM
  #21
Sheriff420's Avatar
Sheriff420
it should be three gaskets. one for the belly pan and one for each head (where it is warped at).
Old Oct 21, 2009 | 05:44 PM
  #22
95RAM360's Avatar
95RAM360
it has 5 gaskets included with it. the two that are warped, plenum, and two that are small and go staight (no middle to it)
this is the product im getting
http://www.autozone.com/autozone/cat...=intake+gasket
is that everything i need?
Old Oct 21, 2009 | 05:47 PM
  #23
AlabamaRam95's Avatar
AlabamaRam95
yep...thats it.
and get a TB gasket and an air cleaner gasket.
Old Oct 21, 2009 | 05:49 PM
  #24
95RAM360's Avatar
95RAM360
will do...
regular tools will be able to do this right? no specialty tools?
Old Oct 21, 2009 | 05:54 PM
  #25
AlabamaRam95
just the fuel disconnect...but its cheap...like 5 bucks or less and they will probably have it in stock.
Old Oct 21, 2009 | 05:56 PM
  #26
95RAM360's Avatar
95RAM360
yea i noticed that on the write up, already grabbed it so i wouldnt forget. alright then, wish me luck, hopefully I can get it start to finish tomorrow. i need my truck for friday
appriciate the help. i honestly thought that this was MAJOR...but its not so thank god...she'll be fixed tomorrow....i hope
Old Oct 21, 2009 | 06:02 PM
  #27
zman17's Avatar
zman17
Retired Moderator - RIP
And a torque wrench. BTW, you"ll gain a little performance and gas mileage by fixing the plenum gasket, but if you don't replace the plate, you will be in the same boat soon. And there is no way the intake gaskets to heads are blown enough that you can hear air. If they were that bad, the thing would run so crappy it wouldn't be funny. Anyway, after you do the plenum, replace the pre cat 02 and the cat (or gut it).
Old Oct 21, 2009 | 06:05 PM
  #28
95RAM360's Avatar
95RAM360
you can def. hear it. very noticable comming from right there. i can feel slight air when i put my hand over that area. but the truck does run great, although i havent been able to roast a tire on dry pavement.
Old Oct 21, 2009 | 06:16 PM
  #29
zman17's Avatar
zman17
Like I said about replacing the plate itself! (with a Hughes plate). Nuff said.
Old Oct 21, 2009 | 07:22 PM
  #30
PurplDodge's Avatar
PurplDodge
You also need new intake bolts. And I'd get the improved plenum gasket from the dealer. I'll see if I can get the P/Ns.
Zoom to the bottom of the page:
http://dodgeram.info/tsb/2000/09-05-00.htm
