Uh Oh...Warped Head?
Old Oct 21, 2009 | 07:28 PM
  #31
dodgeram07's Avatar
dodgeram07
dude it going to cost at least 60+bucks in gaskets and bolts plus time,,,, i would wait to get the hughe plate.... just saying
Old Oct 21, 2009 | 07:33 PM
  #32
PurplDodge's Avatar
PurplDodge
Do it right the first time!!! You'll save yourself around $70 if you just order it now.
Old Oct 21, 2009 | 08:18 PM
  #33
95RAM360's Avatar
95RAM360
i just want the plenum to last until i rebuild it in march-april. ill get the hughes then...but do you think it'll last until then with new gaskets?
Old Oct 21, 2009 | 08:21 PM
  #34
AlabamaRam95's Avatar
AlabamaRam95
it should
Old Oct 21, 2009 | 08:22 PM
  #35
95RAM360's Avatar
95RAM360
can i use the second set of bolts for the intake? thats what cae up when i typed in my truck
http://www.autozone.com/autozone/cat...ifold+Hardware
Old Oct 21, 2009 | 08:31 PM
  #36
CSXfan's Avatar
CSXfan
You don't NEED new intake bolts. The stock ones are fine.
Buy or rent a torque wrench, it'll come in handy. You'll also need a new bypass hose. Chances are you'll destroy the old one when you try to take it off. Good luck.
Old Oct 21, 2009 | 08:32 PM
  #37
95RAM360's Avatar
95RAM360
i replaced that when i did my water pump 2 months ago
and are you 100% positive i can re-use the bolts?
Old Oct 21, 2009 | 08:54 PM
  #38
PurplDodge's Avatar
PurplDodge
No, the stock bolts are Torque-To-Yield. That basically means that you can only torque them once.
Here is what you need:
Gaskets- http://www.napaonline.com/NOLPPSE/(S...+2022009+28707
Throttle Body Gasket- http://www.napaonline.com/NOLPPSE/(S...+2022009+25010
Manifold bolts- http://www.napaonline.com/NOLPPSE/(S...+2022009+29039
Torque those using the pattern in the link that I gave you above. And while you are in there, you might wanna change the cap and rotor, too. And change the thermostat.
Old Oct 21, 2009 | 09:00 PM
  #39
AlabamaRam95
+1 on the bolts...as well as the cap and rotor and tstat. otherwise those are a pian in the butt to do later.
Old Oct 21, 2009 | 09:16 PM
  #40
95RAM360's Avatar
95RAM360
i gotta spend 50 bucks on bolts????
the bolts i posted above were 8.99 can i use those?
