Help,My 1500 4x4 is fast falling apart..
Old Oct 24, 2009 | 05:09 PM
walkingant's Avatar
walkingant
Default Directional Switch?
So the directional switch, multi-switch, if broken internally, could make the following not work?
Turn Signals
Hazard lights
Brake lights.
My headlights & tail-lights work. While I am certain I don't know much, I am just wondering if the brake lights are routed or affected by the directional switch in the steering column???
Or are the brake lights a seperate issue?..coincidence breaks lights not working or connected?
Thanks
Old Oct 24, 2009 | 06:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yup!....
Old Oct 26, 2009 | 03:03 PM
walkingant's Avatar
walkingant
Default Tried a new multi turn signal switch...NO....
Ok,
I replaced my multi-turn-signal switch, still no turn signals, no hazards and no brake lights
Any other ideas? Couldn't find a ground problem.
I replaced the fuses and the flasher and now the turn signal switch...
darn gremlin....*mumblin*
anyway, any help woul be appreciated
Thanks
Old Oct 26, 2009 | 04:19 PM
zman17's Avatar
zman17
Sorry that didn't help. Are you sure you have inspected the wires in the column real good? And you did remove and check the headlight switch too right? And the fuses out under the hood?
Old Oct 26, 2009 | 04:27 PM
95RAM360's Avatar
95RAM360
Originally Posted by walkingant
So I guess no one has a guess on the no turn signals, no hazards and no break lights problem?
Couldn't find any "ground" at the rear at a connector...please expand?
follow the ground wire from the tail light thats all, its a black piece that all the wires go into and comeback out of. you'll know when you see it, my ground broke right out of that harness, re-routed it, and everything worked again
my problem was the exact same thing as yours
Old Oct 26, 2009 | 05:19 PM
walkingant's Avatar
walkingant
Wires looked good, headlight switch too! Changed and/or checked all fuses under the hood and by the drivers door--all good.
When your ground broke, did you still have tail lights/park lights, just not brake lights?
Old Oct 31, 2009 | 03:18 PM
walkingant's Avatar
walkingant
Talking Anyone?
Anyone have any other ideas why I don't have a turn signal, hazard lights nor break lights...still can fix it and need to drive my truck?
Any thoughts would be appreciated!!!
Old Oct 31, 2009 | 03:26 PM
zman17's Avatar
zman17
Since I cost you money for no reason, you probably don't want to listen to me anymore! LOL But, do you have parking lights? I'm afraid at this point, your last option is to replace the headlight switch. Like the multi switch, it can be bad internally.
Old Oct 31, 2009 | 03:49 PM
walkingant's Avatar
walkingant
Default It was you?....lol
Yeah, I have headlights and park lights...all lights, license plate light, markers, tailights, headlights...
Its just those darn no turn signals, no hazards and no brake lights.
That multi turn signal switch was new...plus new flasher (the multi in the fuse box--) plus all new fuses.
Old Oct 31, 2009 | 03:56 PM
zman17's Avatar
zman17
All I can say is, you should download the FSM from the DIY or FAQ section up top and trace the wires, if the headlight switch does not fix it.
