4.56 gears with 35's bring all the final gear ratios back to stock.(thats why the speedo would be dead on again with no computer mods)....which I imagine 4.88's would do for 38 or 40" tires but even 4.88's are kinda usless since our 1500 axles cant reliable handle anything bigger than a 35" tire without chewing up wheel bearings like a drunk would booze or driving like and an old man lookin for the cemetery to rest....seriously if you "use your truck for anything more than a show piece or poser ride you should go with heavier axles....I see so many ads for ram 1500's with 40" tires that either mention "new wheel bearings" or "needs wheel bearings"
Of course there is an exception to every rule I'm sure....
Well, I have 4.56 in mine, and you can do up to 4.88 for sure.
You'll need a new carrier with 4.10 and up, or else get a thick gear. I had a thick gear 4.10 at one time.
