suspension questions
Old Oct 21, 2009 | 10:33 PM
nickkendall's Avatar
nickkendall
Default suspension questions
will i get lift by installing 2500 front springs in my 1500? how much?
how about the rear? i am gonna be swapping axles anyways and figured if i gained any lift i would swap them out aswell..
where can i get some affordable control arms or find the measurements so i can make a set?
how can i tell how much lift i have now? i bought the truck and they didn't know how much or what kind and i looked but there is no names how can i find out how much lift there is?
what would you suggest as far as getting an adjustable track bar?
Old Oct 21, 2009 | 11:48 PM
Weldor's Avatar
Weldor
You will get about 2" from a 2500 v8 coil spring, about 3" from a v10 or diesel coil spring. The rear leaf springs from a 2500 wont work in our 1500's because their wider. A good way to do a cheap lift is to get your hands on some 2500 v10 or diesel coil springs which will give you about 3" up front then buy some add-a-leafs for the rear to lift the back end.
Old Oct 22, 2009 | 12:32 AM
1fast2liter's Avatar
1fast2liter
wrong they will work but you need the shackles from it too. this topic is discused all the time you could find a whole donor truck with good suspension from a 2500 and put it on including the shackles and leaf springs
Old Oct 22, 2009 | 01:45 AM
jasonw's Avatar
jasonw
Site Moderator
For the wider leaf springs to work, you'd also need the u-bolts and associated hardware from the donor truck.
Old Oct 22, 2009 | 02:25 AM
TIMIDONE's Avatar
TIMIDONE
I am still trying to find some V10 or diesel coil springs...amazing how such a simple part can be so hard to find!
