winter rebuild
Old Oct 21, 2009 | 01:48 PM
Dr Donut's Avatar
Dr Donut
Default winter rebuild
Okay guys so I'm putting some plans together for a rebuild/upgrade on my 01 318. I just want to go through and replace the rings oil pump etc, I also wanted to add a new camshaft and swap some 360 heads on. I need help figuring out what parts I need I would also like to do a little work to the heads. I've got about 6-700 dollars to put into this so far.
Old Oct 21, 2009 | 01:49 PM
95RAM360's Avatar
95RAM360
id swap out the intake as well if you have the extra cash...and maybe a better TB
Old Oct 21, 2009 | 02:11 PM
lastrights's Avatar
lastrights
1.7 rockers instead, a cam may be to much for stock motor
Old Oct 21, 2009 | 02:51 PM
dakotas ram's Avatar
dakotas ram
360 heads are the same as 318 heads
Old Oct 21, 2009 | 03:00 PM
Dr Donut's Avatar
Dr Donut
Really? seems like a stock motor would hold up just fine to a mild cam? ( I love the way v8's sound with a cam)
Old Oct 21, 2009 | 03:04 PM
Mowhawk's Avatar
Mowhawk
try talking to squirrels about the cam. He as a cam in his ram, but his heads are different. Our blocks are fine for a cam, as long as yours is in good shape and isnt compromised, you can put a cam in. Its all how much work you wanna do.
Old Oct 21, 2009 | 03:18 PM
Dr Donut's Avatar
Dr Donut
well hopefully I don't need to replace anything other than rings oil pump and the usual stuff but i know someone who does machining so everything will be checked for specs while its apart. I am hoping that by doing this before something goes wrong i may need to replace less parts.
Old Oct 21, 2009 | 03:26 PM
Mowhawk's Avatar
Mowhawk
Preventative maint. is the best kind there is.
Old Oct 22, 2009 | 01:53 AM
lastrights's Avatar
lastrights
dont buy a cam for the sound, the 1.7 sound awesome on mine with the longtubes sounds like i have something mild
Old Oct 22, 2009 | 07:05 AM
Twisted Metal's Avatar
Twisted Metal
I agree with Last. Buying a cam for the "sound", isn't really away to shop for one. Bear in mind, to get that good deep "lope", its probably gonna cost you more than a cam(i.e. valvetrain,heads, or machine work for heads). Also, think hard about how you drive your truck. What rpm range? What lift/seperation is gtonna get you what you want in the rpm your looking for. Basically do a little homework before doing it. I have read and been told that our engines respond quite nicely to am RV style(read low end torque) cam, or even a mild street cam.
