Wish Me Luck...Plenum Fix
Old Oct 22, 2009 | 12:01 PM
95RAM360's Avatar
95RAM360
Default Wish Me Luck...Plenum Fix
ok so im doing my Plenum with the hughes plate and intake gasket kit today. i already have everything apart except the manifold, and fuel lines.
This is my first time attempting something like this, but its going very smooth thus far.
I never knew i had a plenum leak. i always looked through the tb, andnever saw oil. well once i got the TB off today, (cuz i wanted to huges plenum plate it anyways) thats when i saw the oil.
So for those who dont think thy have the plenum leak. take the TB off all together to get your best visual. looks can be decieving as i have now learned.
I hope nothing will come out wrong during this. but at the same time im doing the plugs, dist.cap, rotor, wires, coil, and the other valve cover gasket. (did one yesterday and found the bad intake which lead me to do this)
please wish me luck, i always run into a problem when workin on my vehicles. but its going smooth as i said **knock on wood**
Hopefully this works...
Old Oct 22, 2009 | 12:49 PM
AlabamaRam95's Avatar
AlabamaRam95
Good Luck!!
holler if you need anything
how did you get the hughes kit so fast?
Old Oct 22, 2009 | 01:30 PM
95RAM360's Avatar
95RAM360
overnighted should have it by 3....dont have it yet just tearing it apart....but i ran into a problem....how do i separate the fuel injectors from the fuel rail? ive unhooked them, and removed the clips, and the fuel rail is all disconected so how do i separate the two?
Old Oct 22, 2009 | 01:32 PM
95RAM360's Avatar
95RAM360
decided to do thermostat and gasket as well, now with a new thermostat, i know with most they have a jiggler vlve to line into proper position, now can this be set any which way?
Old Oct 22, 2009 | 01:53 PM
J415's Avatar
J415
when you put the stat on, remember to burp it. some people forget and when the temp goes up, they think it's a defective stat. the stat itself should be positioned in the inset of of the manifold. if you have any doubts, go and practice at the boneyard.
Old Oct 22, 2009 | 03:18 PM
ridehard1's Avatar
ridehard1
Default changing injectors
The injectors just pop out . Just pull up with a twist. Goodluck!!!
Old Oct 22, 2009 | 03:21 PM
PurplDodge's Avatar
PurplDodge
Make sure you use the tightening pattern listed in your Haynes or FSM manual.
ridehard1's Avatar
ridehard1
how do you "burp" the stat?? By heating it??
Old Oct 22, 2009 | 03:34 PM
zje400ex's Avatar
zje400ex
Good luck! Let us know how bad it is replacing the intake. My truck will be getting the hughes plate soon
Old Oct 22, 2009 | 03:36 PM
95RAM360's Avatar
95RAM360
yea i got the fuel rails off, i wsnt pulling up hard enough (didnt want to damage them)
all i have before i take the intake off is that damn pipe that goes to the exhaust in the back, i cannot get the friggen thing off.
other than that everything has gone good. everything is clean. (spent 2 hours cleaning all the sludge up.)
and i have a haynes repair manual, and bought a torque wrench, soi know the tighten pattern
and yea how do you burp it? when i did my WP, i just filled, put heat on full blast started it, an added accordingly and i had nice heat and ran at a constant 195
im gunna get some pics of my work up
