2001 ram 1500 4x4 auto 5.2L slipping from 1st to 2nd ... common problem?
Old Oct 22, 2009 | 08:28 PM
moparmiami's Avatar
moparmiami
Default 2001 ram 1500 4x4 auto 5.2L slipping from 1st to 2nd ... common problem?
I have a 2001 dodge ram slt 4x4 automatic 5.2L truck was running ok but no developed a transmission problem. The transmission kind of slips when shifting from 1st to 2nd gear.... i have to press the gas pedal all the way down till it finally kicks in the 2nd gear.... the rest of the gears are working fine....
I did some research online and found out its a common problem. Any one had a situation like this? Am i looking at a total rebuild?
My transmission fluid level is perfect.
Can i use a transmission additive? i heard good things about TransTune...
Any help would be greatly appreciated.
I scanned the truck but has no codes in it.
Old Oct 22, 2009 | 09:01 PM
95RAM360's Avatar
95RAM360
have you had the bands adjusted?
Old Oct 22, 2009 | 10:05 PM
moparmiami's Avatar
moparmiami
What are bands? i have no idea on bands... where are they located and how are they adjusted? thanks
Old Oct 23, 2009 | 05:07 PM
AlabamaRam95's Avatar
AlabamaRam95
additives are not a great investment...but if you must--use seafoam. it will work for you for about 5-600 miles just until you can have the bands adjusted. if you dont know what they are then i dont suggest adjusting them DIY. have your local trans shop do it for you.
