Chatter.....
Old Oct 22, 2009 | 11:08 PM
mr freeze's Avatar
mr freeze
Default Chatter.....
I was changing the oil in my truck today and noticed a noise coming from near the pcv valve.If I moved the hose around a little it wasnt as noticeable.It was a chatter like sound or maybe a tap.Not sure.Any ideas??
Old Oct 22, 2009 | 11:52 PM
95RAM360's Avatar
95RAM360
inside the PCV valve theres a little jiggler. with it flappin around it could make a chatter noise, but if i remember correctly, if theres excessive suction the plenum might be goe. check down in your TB and see if theres oil.
I didnt see it until i actually took off the throttle body and looked in. found i had a bad plenum. so as of right now my intake manifold and hughes plenum plate is in my bathroom! (cleaning manifold)
Old Oct 23, 2009 | 01:46 AM
Sheriff420's Avatar
Sheriff420
clean it outside with carb cleaner and paper towels. it'll be easier. then you can burn the paper towels after and get a nice little (brief) fire.
