Doesnt blow really hot air like it should...
Old Oct 24, 2009 | 09:25 AM
Prodirt6000's Avatar
Prodirt6000
Default Doesnt blow really hot air like it should...
Hey everyone,
I got a question because when my truck is at operating temperature it doesnt blow very hot air. It blows some, but nothing like it should. Truck temp stays right at the right spot, doesnt get too cold and doesnt over heat. Do I have the wrong temperature thrermostat? The truck is from the south so I dont know if they have something in there different. Now its in Vermont and its getting cold!!
K thanks everyone let me know what you think
Old Oct 24, 2009 | 09:29 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The heater core is probably clogged. You can try back flushing it and see if it helps.
Old Oct 24, 2009 | 09:59 AM
moparama's Avatar
moparama
Thats where i would start too. I dont see dodge using diff temp sensors diff. areas
Old Oct 24, 2009 | 10:14 AM
Eddielx's Avatar
Eddielx
I would check the heater core like the others said you should be able to feel the hose to see if its hot.If ones hot and the other is not then its the heater core.It could also have a 180 stat.
Old Oct 24, 2009 | 10:19 AM
95RAM360's Avatar
95RAM360
i have somewhat the same problem and ive noticedthat with it on full blast hot its luke warm, but on any other setting lower its hot air. dont know how that happened, but try it, see it the temp changes wth diff. gears.
you say its right in the right spot...well whats the operating temp on it?
mine runs 195 consistantly
Old Oct 24, 2009 | 10:26 AM
Eddielx's Avatar
Eddielx
When the heater core is is somewhat clogged it lets alittle bit of water go passed and when your fan is on high it cools it down too fast for the amount of water going by..I had this happen to me on one of my mustangs
Old Oct 24, 2009 | 10:28 AM
95RAM360's Avatar
95RAM360
so i have a somewhat clogged heater core? im gunna bleed it the right way when i get my manifold back on, and we'll see if that makes a diff. but i can hear some water that sounds to be in the dash when i hit the gas sometimes. but not all the time, maybe 1nce a week ill hear it
Old Oct 24, 2009 | 11:02 AM
Prodirt6000
Where exactly is the heater core? How do you go about unclogging the heater core? My temp is just a little bit to the right of the halfway line on the gauge
Old Oct 24, 2009 | 11:08 AM
zman17's Avatar
zman17
The heater core is under the dash, pita, but there is a good write up in the DIY section. To flush it just disconnect the hose from the WP and the other one probably has a connection about half way next to the valve cover. Back flush it first, which would be the hose running next to the VC IIRC.
Old Oct 24, 2009 | 11:24 AM
Prodirt6000
Ok I'll take a look at the DIY. Thanks
