Transmission Issues Again
Old Oct 24, 2009 | 08:08 PM
Trey318's Avatar
Trey318
Default Transmission Issues Again
Oh boy.. I get in a wreck and then have tranny issues to deal with. The transmission seems to shift from 1-2 alright most of the time, although occasionally, the RPM's will travel up to around 3k before it shifts for some reason. The problem, however, is that it doesn't want to downshift back to 1st. It started only doing this every once in a while at the beginning of the week, but now it's doing this constantly.
Fluid checked out fine, although the dipstick was bent at the bottom, oddly.
Any suggestions as to what this might be? When I changed out the Governor pressure sensor and solenoid, there were a lot of metal particles in the pan. I'm just hoping that the little screen on the sensor isn't clogged again.
I'm planning on replacing the fluid and filter tomorrow, and cleaning things out again. I'm also going to adjust the bands. Anything I should be looking for?
Old Oct 24, 2009 | 11:16 PM
Trey318's Avatar
Trey318
Bump <.<
Old Oct 25, 2009 | 12:34 AM
dodgeram07's Avatar
dodgeram07
look up governor cylinoid,, or something like that control the shift
Old Oct 25, 2009 | 03:36 AM
jasonw's Avatar
jasonw
Site Moderator
I might look into trying to prove that her little hit pushed your transmission "over the edge," so to speak. See if her insurance company won't pay for a new tranny.
Old Oct 25, 2009 | 09:24 AM
Trey318's Avatar
Trey318
I've put in a new one about 2-4 months ago or so.
I could try it, but I don't think that'll fly lol
Old Nov 3, 2009 | 11:33 PM
Trey318's Avatar
Trey318
New fluid, cleaned the already replaced governor pressure sensor and solenoid, and adjusted the bands. Seemed to have helped initially, as the downshifting went away and it started shifting normally, but it seems to be back with a vengeance. <.<
Old Nov 4, 2009 | 05:26 PM
Trey318's Avatar
Trey318
On my drive to school today, the check engine light came on. I got it checked afterward, and it turns out, the governor pressure is out of range. So I suppose the parts I purchased 3 months ago, are already bad. I suppose that indicates crap quality.
Old Nov 4, 2009 | 05:54 PM
mikey0469's Avatar
mikey0469
not true!! metal shavings or any other type of grit in the tranny can cause that solenoid to misproperly function. check your pan. get it cleaned out, flushed and put an external in-line filter on it.
Old Nov 4, 2009 | 05:55 PM
Augiedoggy's Avatar
Augiedoggy
or something else is causing excessive metal shavings that are fumbling up the solenoid or sensor...
Old Nov 4, 2009 | 07:11 PM
Trey318's Avatar
Trey318
When I replaced the solenoid and sensor around 3 months ago, there were some metal shavings and whatnot in the pan and solenoid/sensor. New ATF, sensor, and solenoid and I cleaned out the pan and everything pretty good.
2 weeks ago, I dropped the pan and checked things out. The fluid was pretty clean, but the filter was slightly dirty, so I replaced it. New ATF again, and I dropped the governor body and inspected it. The solenoid was kinda dirty, and my dad cleaned it up a bit. Black crap oozed out of the solenoid, but it finally cleaned up, and everything was reinstalled.
It worked fine again until two days ago, so I'm pretty sure there are no more excessive shavings and whatnot since.
