My truck was Arnold's
Old Oct 27, 2009 | 11:46 PM
Gotta feed them horses's Avatar
Default My truck was Arnold's
I decided to get the carfax on my truck. I found out that it was originally a california truck and passed emissions several times. There were 29 records many of which were me running into ppl. What difference does it make that the truck was originally a CA model? I feel like it's not as good somehow, and that explains the weird exhaust system. It's a 1996 2500 v10
Old Oct 27, 2009 | 11:51 PM
Miami_Son's Avatar
Miami_Son
Not as good how? The only difference bewteen a CA model and a 49-state model is the addition of some extra emissions equipment to meet the lower regulations we have here. The trucks roll off the same assembly line and use the same parts.
Old Oct 27, 2009 | 11:52 PM
mikey0469's Avatar
mikey0469
well my truck i believe is a california truck, even though it was bought in oregron from the originial owner. as far as the exhaust system goes, i had 3 cats, two precats directly behind the exhaust manifolds and a larger cat where both sides of the exhaust came into one. i got rid of the big cat and ran duals off of the smaller cats.
Old Oct 27, 2009 | 11:59 PM
Cereal Killer's Avatar
Cereal Killer
Same truck more a less. The only difference with the Cali models is some pain in the *** emissions **** that you can get rid of if you don't live there anymore. Extra catalytic converters, and oxygen sensors that you can ditch, and then get your PCM re-flashed to compensate for the missing oxygen sensors.
Old Oct 28, 2009 | 12:02 AM
It only has one catalytic converter.... and I can't find one to replace it because all the ones I find are for the other model trucks. The o2 sensors are a pain in the butt too, i don't know what to do with them, I want them gone, because I want to replace the cat with a y pipe. Where do I get the PCM reflashed?
Old Oct 28, 2009 | 12:11 AM
dodge15004x45.9's Avatar
dodge15004x45.9
What did you do to that truck!
Old Oct 28, 2009 | 12:14 AM
Cereal Killer
Well if you only have one cat you should only have 2 oxygen sensors. Just have the guy at the exhaust shop put bungs for the 02 sensors in your new Y-pipe, or right after it. The post cat 02 sensor you can replace with a spark plug non-fouler or a 02 sensor simulator so you won't get a CEL from your missing catalytic converter.
Old Oct 28, 2009 | 12:38 AM
dakotas ram's Avatar
dakotas ram
you hitting people?, thats great
i thought you were gonna says it was actually schwarzennegar's
Old Oct 28, 2009 | 12:40 AM
dodge15004x45.9
I was looking for a movie. lol.
