How can I tell what my fuel capacity is?
Just got my 1997 Ram 1500 5.9L, extended cab, short bed. I think the fuel gauge may be stuck above 1/4 tank. It was there when the truck was delivered, and I have driven close to 100 miles since and it is still there. The guy who delivered the truck said that he filled up whenever the truck got close to 1/4 tank. So he never saw it go lower.
How can I tell if I have a 26gal tank, or the 35gal tank. I plan on running out and filling up the tank after dinner, but even if the fuel guage gets stuck at 1/4 tank, I just can't figure out how many miles that gives me per tank on average.
^ Not all the time. Right now, I would just fill up and if you go over 24 gallons or so, then you more than likely have a 35 gallon tank If you only squeeze in 19-20, then I'd say you have the little tank.
I just filled up and she took 15gal. I guess that proves that I have a small tank. Now to see what kind of mpg I get on 87 oct. Next will be 91 oct.
Trending Topics
Actually, unless you are running a tuner or pinging, octane reading isn't going to make a difference. 89 octane is the preferred in these motors from the factory I think. It might be 87, but I don't think so.
All octane does is control the rate at which gasoline detonates. If the motor doesn't need it, then you might as well take that extra $10 or so and light it on fire when you get home. It's just a waste.
Stick to what you know, Max. Extended cab, short bed here with a 34 gallon tank. There were 24, 34 and 35 gallon tanks used on these Rams.
