What is this? (with pics)
ok everyone here is right, those black and red lines are the front accuator... cant tell if is to the front or the rear,, but that one in pic 2 with the 90* corner is the vent line also to the transfeer case, or trans i cant remember, but that is the vent line, sounds like you have alot of vac probalems with thsi truck, but thats what everything is..
on
having a broken vacuum line will mess with engine performance.
i've heard that you can take the universal windshield washer fluid hose (the one that goes to the wipers themselves) at the parts store and use it to patch vac lines because it is a perfect fit. some sealant on either end of the patch after sliding it on wouldn't hurt.
It's beer time now, but I'll splice them back up in the morning and see what happens.
for 1,00 bucks, i could put a hell of a 4wd system on there... but one thing i will suggest, dont even worry about the vac lines to the frot axle. put your truck in 4wd, high or low, and try to spin the drivehaft, like have someone in the truck, in drive, holding foot on brake and reach under and see fi it turns, if it does, the 4wd is engaging, but the front axle is not, ( the cad unit is still reading neutral vac so it will keep the fork inside in 2wd) then put it back in 2wd, park, and go inside and buy the posi lock cable, and forget the vac all together, vac sucks and is unreliable...
that is the one you need
http://www.4x4posi-lok.com/app_dodge.html
OK, so mystery solved. The white line is the supply vacuum for the t-case from the manifold, the green is a vent (just hangs open near the back of the engine.) The red and black run the front axle.
Patched everything up with some shrink tubing (Radio Shack.) Worked great.
4WD is good to go now!
meanwhitemopar: Thanks for the tip on the posi-lock. I've got some other problems to solve before I have the change to spend on it though...
Thanks to all for the help -- I was just about to tear the disty out and look for something to plug the green vacuum line into!
