top end rebuild
Old Nov 1, 2009 | 11:09 PM
millertime 1321's Avatar
millertime 1321
Default top end rebuild
hey fellas. i just bought me a hughes fi airgap intake manifold. its part of a step by step top end rebuild. i eventually plan on replacing the cam, getting iron ram heads with 2.02 valves, sturdier springs, roller rockers, and hardened pushrods. now heres my question. does anyone know anything about hughes shaft mount roller rockers for our magnum motors. theyre 1.65:1 ratio so they wouldnt increase the cam profile as much, but are they sturdier with the shaft? or do they create less friction? or should i just stick with the harland sharps?
Old Nov 2, 2009 | 12:24 AM
lastrights's Avatar
lastrights
i would say harland sharps adj. 1.6
Old Nov 2, 2009 | 01:21 PM
millertime 1321
i was thinkin along the lines of the 1.7 non adjust rr's. i think thats what most people have on this forum and they say they love em.
Old Nov 2, 2009 | 01:30 PM
lastrights's Avatar
lastrights
yeah but if your planning on a cam thee 1,7 not a good idea, the point of the 1.7 is a cheaper way to get power without doing all the work for a cam
Old Nov 2, 2009 | 04:23 PM
millertime 1321
true. that was part of the reason i was considering the 1.65 shaft mounts from hughes, i thought they might facilitate a cam swap better
Old Nov 2, 2009 | 05:23 PM
AlabamaRam95's Avatar
AlabamaRam95
what cam are you going with? trying to figure out what rocker arm you want is kind of a mute point until you know what valve/lobe lift you want.
Old Nov 2, 2009 | 11:05 PM
millertime 1321
well i was gonna go with a hughes cam, if i got one at all. alot of the guys on here are happy with their higher ratio roller rockers and i figured if i was happy with the way those wroked out i might leave off the cam swap for the far away future when im buildin a serious racing machine, but for now a cam swap would only happen after all the other upgrades and only if i was still looking for a little better performance.
