NGK Iridium IX plug experiment over.
Old Nov 2, 2009 | 12:20 PM
aim4squirrels's Avatar
aim4squirrels
Default NGK Iridium IX plug experiment over.
Well,
I had been running the NGK Iridium IX plugs with my MSD ignition system for a while. I was hoping for a little more longevity from my plugs as the MSD eats thru the coppers pretty fast.
I was getting random misfire codes from multiple cylinders around the 3K RPM mark at certain part throttle and WOT instances. And I blamed about everything I could think of, the MSD system, the wires, the cap and rotor, about 5 different plug gaps, everything except the plugs themselves.
It was the plugs.
Well, the plugs and the MSD combined, I believe.
I did a little research on the MSD box and the NGK iridium plugs. Here's what I found:
Seems as though an added "benefit" of the NGK plug is that they fire at about 5K volts less than the standard plugs. In an engine with a weak ignition (especially weak at high RPMs,) this could be a good thing. The problem is that the MSD box delivers 3 "regular" sparks per cycle at under 3K RPMS, and "one powerful spark" above 3K. I believe the "one powerful spark" was jumping the gap too early and causing misfires. Switched back to the NGK V-powers and the problem hasn't repeated yet.
I will say that the V powers have been the best plug I have found. The Autolite 3923s fouled too quickly (about 500 miles and they engine was noticably rougher), the Champion truck plugs were decent, but the NGKs have the smoothest idle and best off idle throttle response of all the plugs I've tried.
Old Nov 2, 2009 | 12:33 PM
AlabamaRam95's Avatar
AlabamaRam95
+1 on the vpowers. i have been running the vpowers with performance distributors ignition. the vpower is the best plug for my truck as well.
Old Nov 2, 2009 | 12:36 PM
lastrights's Avatar
lastrights
is the ix the iridiums ??
Old Nov 2, 2009 | 12:41 PM
wjxavier's Avatar
wjxavier
i just bought a set of autolite 3924's...we'll see how they hold up.
Old Nov 2, 2009 | 12:42 PM
wjxavier's Avatar
wjxavier
*sorry double post*
Old Nov 2, 2009 | 02:28 PM
aim4squirrels
yes the NGK IX plugs are iridium plugs.
Old Nov 2, 2009 | 05:01 PM
lastrights's Avatar
lastrights
i have iridium they work fine , would it be better to go to the v plugs , i only had the ix in for about 4ooo miles
Old Nov 2, 2009 | 05:03 PM
aim4squirrels
If you're not having issues, then use them. They're $7~$8 a plug, might as well get your money out of them.
If you don't have a 6A ignition box, then the plugs aren't going to fire harder.
