injectors
Old Nov 4, 2009 | 01:13 AM
J415's Avatar
J415
Originally Posted by aim4squirrels
Start by running a bottle of Chevron fuel injector cleaner on a 1/4 tank of gas. Then buy a cheap ultrasonic ***elry cleaner and a bottle of Chevron Techron. Fill the basin with the Techron, drop in however many injectors you can and turn on the machine for about 15 minutes.
So by doing this, will it bring the injectors back to a "like new" condition?
Old Dec 16, 2009 | 09:17 PM
bvincent's Avatar
bvincent
squirrels, question?
The yellow Ford / Bosch 19# design III injectors have 4 holes in the injector.
Spray pattern helps with atomization......I know the jeep guys will swap them out for a little better throttle response and control.
Would the 5.2 benefit from the design III?
Old Dec 16, 2009 | 09:43 PM
pcfixerpro's Avatar
pcfixerpro
Very interesting... im going to research this now. I would still like to hear what squirrles has to say.
Old Dec 17, 2009 | 07:26 AM
aim4squirrels's Avatar
aim4squirrels
I've heard of that swap too, Ford runs at 39psi, dodge at 49 psi so the 19# injectors would be 23.87lbs in a Dodge. That's a slight boost over stock, so I would imagine you'd run a bit rich. I'd be sure to know the measurements of the stock Dodge injectors and compare to Ford's before you buy.
I've also heard that the 2001 Dakota 4.7L runs an injector that has four pin holes and would be a similar type swap.
Better atomization is always a plus. I don't know if it's worth the 300 bucks, but it can't hurt.
It's probably not as good as an injector flushing that a diesel shop can do, but it a hell of a lot cheaper.
EDIT: that's a 2001 Dakota, not 2002, sorry.
Old Dec 17, 2009 | 09:21 AM
jbomb's Avatar
jbomb
I talked to hemifever about this a little with my truck. I had the stock 19lbs. injectors with my 408 and I knew I needed larger injectors. I needed to bump up to atleast 24lbs. I asked him if I wouls get worse gas milage tho and this is what he said (remember he is an sct tunner programmer and has and uses a chassis dyno)
your engine needs X amount of fuel and air to run properly. In closed loop the fuel trims keep it in the 14.x airfuel range. With those little injectors, your fuel trims would have been max'd out and still not providing the correct ratios. With the larger injectors, the fuel trims can keep fueling where it needs to be in closed loop. At WOT, 12.8 airfuel is 12.8 airfuel no matter the injector size so have Marty get that dialed in with your wideband gauge.
I know that the 2000-2002 rams came with the 24# injectors so I bought some of thoes at a junkyard and ebay cheep. The only thing is I had to buy a wiring harness and cut-solider new connectors to fit the 24#ers. If you have a stock motor without an sct be careful about this mod
I can't recall all your specs right off, was there a need to go with the 24's? Did we determine you were running out of fuel? If not, I wouldn't put the in. If you need them, you may need some idle fuel pulled and your WOT fueling will probably be rich and we'll need to curve that. Do you have a wideband a/f gauge?
Old Dec 17, 2009 | 10:41 AM
aim4squirrels
Jbomb's stuff is exactly right. You don't need bigger injectors unless you have more cubes or more boost then the current injector can squirt at 100% duty cycle. Now, more injector spray holes may increase fuel atomization and result in better economy and/or better throttle response. But is that worth $300? Probably not, unless you need to replace bad injectors or go bigger.
Old Dec 17, 2009 | 11:49 AM
pcfixerpro's Avatar
pcfixerpro
The reman ones on ebay are about half that cost or lower.
Old Dec 17, 2009 | 12:31 PM
dakotas ram's Avatar
dakotas ram
http://witchhunter.com/
Old Dec 17, 2009 | 01:06 PM
jbomb's Avatar
jbomb
Hey thanks for that link dakotas ram, good to keep in mind if one day I decide to drop a boatload on some injectors.
Old Dec 17, 2009 | 07:53 PM
bvincent's Avatar
bvincent
with stock 24# and the truck already running a good A/F ratio. There is probably no need to swap. The Design IIIs are found in many 4.6 Ford Mod motors. THe 19# Design IIIs are either Yellow or Orange. They are found in many car models. Pick em up at a U-Pull -It yard for 5-10 bucks a piece. Throw em in a Jewelry cleaner with seafoam and place new o-rings on them. Inexpensive mod.
I did this in a 4 cyl Jeep with good results. But those motors run lean from the factory.
