injectors
Old Nov 3, 2009 | 12:43 PM
lastrights's Avatar
lastrights
Default injectors
when i order the airgap i want the full benifit and want to order new injectors and orings, is there a way i can clean the ones on there now they have 131xxx miles on them or i could maybe go with new ones that really get tested ??
http://cgi.ebay.com/ebaymotors/96-99...Q5fAccessories
Old Nov 3, 2009 | 01:24 PM
mikey0469's Avatar
mikey0469
almost any machine shop will clean injectors. At least the ones around these parts for diesel engines.
Old Nov 3, 2009 | 01:45 PM
aim4squirrels's Avatar
aim4squirrels
Start by running a bottle of Chevron fuel injector cleaner on a 1/4 tank of gas. Then buy a cheap ultrasonic ***elry cleaner and a bottle of Chevron Techron. Fill the basin with the Techron, drop in however many injectors you can and turn on the machine for about 15 minutes. Get new injector O-rings from Felpro to make sure they are made of Viton.
The only reason you need new injectors is if the internal windings have broken or it's so clogged it's unrepairable. An injector is a simple electromagnet, when a charge is applied, the piston opens and the pressure in the fuel system squirts the gasoline.
Test the ohmic resistance of each injector before you replace them *****-nilly. Spec'd resistance is 12 ohms +/- 10%, so 10.8-13.2 ohms. You can also listen to the injectors with a mechanic's stethoscope and probe each injector and listen for a click when it fires.
Old Nov 3, 2009 | 01:58 PM
Cereal Killer's Avatar
Cereal Killer
haha it blanked out j-e-w- in ***elry...
I guess if you were set on buying injectors you could get slightly bigger ones? Would that not be an upgrade?
You are adding more air with the airgap correct?
Old Nov 3, 2009 | 02:31 PM
lastrights's Avatar
lastrights
how would you submerge them when they get connected to electic , wouldnt the electric part of it get messed up >>?
Old Nov 3, 2009 | 02:39 PM
lastrights's Avatar
lastrights
about the airgap its say on hughes website in the info.. it says 6 more miles to the gallon could you vouch for that or is that fiction you think ??
Old Nov 3, 2009 | 03:12 PM
aim4squirrels
You can submerge the entire injector in solution to clean it. There aren't any chips or resistors in the injector to screw up. Just be careful when you unhook the injectors from the harnesses as the little clips are very easy to break. I had to cut all mine off and wire on new connections because they weren't staying locked on.
You can get 6 MPGs by driving your truck downhill, in neutral, with the engine off. Otherwise, I ain't buying it.
Stock injectors can probably get you to 450 to 500 hp before you need to worry about bigger. You can even swap in a cam and hi flow heads and stay under that.
More injector doesn't mean more power, unless you have maxed out the injector's pulsewidth at WOT and are still running lean. The only way to know that is with a wideband sensor.
If you order a new airgap, you will need an SCT tuner to dial it in a bit. It'll still run with it just fine, but you won't be maxing out the perfromance without a good tune.
Old Nov 3, 2009 | 04:55 PM
jasonw's Avatar
jasonw
Site Moderator
+1 for everything Squirrels said.
Others that have purchased the airgap claim the 6 MPG is bogus, not a one so far has got that. Most have said little to no MPG difference, but nice power difference.
Old Nov 3, 2009 | 05:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A little more power with none to very little MPG, $600. A little more power and more MPG, fixing your blown stock plenum with a Hughes plate for $90, Priceless! LOL
Old Nov 3, 2009 | 07:52 PM
lastrights's Avatar
lastrights
lol nice
