Loud Squeaking
Old Nov 3, 2009 | 07:54 PM
elementalnature's Avatar
elementalnature
From: Home: Southern KY; Stationed: Southern California
Default Loud Squeaking
So a new issue has arisen. When I turn left or right there are is a loud squeak that will continue as long as I am holding the wheel. Also happens when I go over bumps and such.
From what I've read its either control arms or the transmission linkage under the drivers side foot pedals.
Any input?
Postnote: Anyone know the torque specs for our trucks? Took the wheels off to clean them up, threw back on and tightened them down with a breaker bar and nineteen mm deep well. They've loosened themselves and its time to torque them down.
Old Nov 4, 2009 | 08:20 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be BJ's. Get a Haynes manual and see if you are up to the task. Plus the manual gives you all the torque specs you need. As far as the wheels go though, you have aftermarket wheels, so I don't know if the oem specs would apply.
Old Nov 4, 2009 | 08:40 AM
halfamil's Avatar
halfamil
Torque specs are for the strenth of the stud and lug.It is 95 ft.lbs.
Old Nov 4, 2009 | 08:44 AM
halfamil's Avatar
halfamil
Sorry can't say much about the noise,If it will do it going very slow get somebody to walk beside it to pinpoint it.
Old Nov 4, 2009 | 09:40 AM
zman17's Avatar
zman17
I know, I just didn't want to be the one to tell him and have a wheel fall off or something.
Old Nov 4, 2009 | 10:14 AM
95RAM360's Avatar
95RAM360
i throw this out there....have you checked the PS fluid?
Old Nov 4, 2009 | 12:28 PM
elementalnature
Actually, I added Prestone Power Steering fluid to top it off. Come to think about it, that is about the time all of this started really...
I don't think its the ball joints. It if was, the wheels would be wobbling about and I could freely move them as if the lugs were loose. I replaced two uppers and two lowers on my Jimmy.
Any other ideas?
Remember, happens when going over bumps, general decompression and expansion of the suspension, and turning.
Old Nov 4, 2009 | 12:45 PM
zman17's Avatar
zman17
Any other ideas?
Not true. If they or one is rusted and seized up, it could squeak before it gets loose.
Old Nov 4, 2009 | 12:50 PM
elementalnature
That's all I need are more ball joint replacements
Old Nov 4, 2009 | 12:52 PM
95RAM360's Avatar
95RAM360
you should flush the PS system and make sure all the fluid is the same when you refill it. dont mix match brands
