What alternator do I have???
Old Nov 3, 2009 | 08:55 PM
011500Ram's Avatar
011500Ram
Default What alternator do I have???
I've searched and searched under the hood for an Id sticker or plaque, and I've come up dry. I want to know how many Amps my alternator is putting out, and I know that these trucks came with 8 different alternators.
I have an 01 1500 318 4x2, extended cab base model if that helps..
Old Nov 3, 2009 | 09:09 PM
J415's Avatar
J415
Email chrysler for a build sheet. It'll tell you everything you want to know.
Old Nov 4, 2009 | 02:04 AM
dakotas ram's Avatar
dakotas ram
generator ratings
type part number
rated sae amps
engines
minimum test amps
denso 56028920ab
136
3.9l/5.2l/5.9l
gas
100
denso 56029913aa
117
3.9l/5.2l/5.9l
gas
90
bosch 56028237ab
117
3.9l/5.2l/5.9l
gas
90
bosch 56028238ab
136
3.9l/5.2l/5.9l
gas
100
denso 56027221ad
136
5.9l
diesel
120
bosch 56028239ab
136
5.9l
diesel
120
bosch 56028560aa 136 8.0l 100
denso 56028920ac 136 8.0l 100
Old Nov 4, 2009 | 05:29 AM
xray99's Avatar
xray99
Go with the high output.
Check the ALT fuse, it should be close to that, 130 something.
If they give you the wrong one [lower output and you're supposed to have higher], the top bolt won't fit.
Otherwise they look identical, and it will install, except for that bolt.
Side by side the high output is a little stockier.
Just been through it a couple weeks ago, truck same stats as yours except 96.
Pull it and bring it in, not only do you need it for the hefty core charge, but you may also have to
swap belt pulleys, I did.
Old Nov 4, 2009 | 10:55 AM
pavement_hater's Avatar
pavement_hater
The post on the 136a is bigger than the 117a. Found this out when I made the swap. I just put a new end on the cable. But as has already been said. Email Chrysler for the build sheet. Then you will know what you have.
Old Nov 4, 2009 | 02:26 PM
011500Ram's Avatar
011500Ram
How do I email Chrysler? My alternator is working fine, I just need to know what it's putting out.
Old Nov 4, 2009 | 02:57 PM
dakotas ram
http://www-5.dodge.com/wccsapp/unive...ull&category=U
in the reason, ask for build sheet and recalls
Old Nov 4, 2009 | 03:19 PM
011500Ram's Avatar
011500Ram
Cool, I just sent off for it. Thank you for the help.
