heater only blowing hot
Old Nov 4, 2009 | 01:35 AM
dodgeboy01's Avatar
dodgeboy01
Default heater only blowing hot
okay so i been letting this problem slide with out tryingt to fix it. so my 2001 dodge ram only blows hot. even if you turn the temp **** to cold(blue..lol) and its blows super hot. even when u turn it to a/c is blows hot.. my wife's dad has a 95 dodge that does the same thing so i know this is probly somewhat common.. how do i fix this or ??? please help any advice would be great
Old Nov 4, 2009 | 07:30 AM
95RAM360's Avatar
95RAM360
sounds like the temp *** isnt doing what its supposed to, take it aprat and check the wiring
Old Nov 4, 2009 | 07:31 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The blend door is broke or the mechanism that operates it, or the control module itself is bad. Those 2 trucks operate differently. The 2001 has a little electric motor down by the blend door that goes bad. The 95 probably uses a cable IIRC.
Old Nov 4, 2009 | 07:33 AM
95RAM360's Avatar
95RAM360
yes i do have cables...
Old Nov 4, 2009 | 08:15 AM
Twisted Metal's Avatar
Twisted Metal
Is the A/C charged? Compressor working? You didn't say, so I have to ask.
+1 on the blend door check.
(the SEARCH feature here makes thing easier, try it)
Old Nov 5, 2009 | 01:56 AM
dodgeboy01's Avatar
dodgeboy01
yeah a/c was good... i took it out but i never blow cold even witht he a/c pump and etc.. but the wiring is good but i'm not even sure were the blend door it or anything. i honest don't know much about the wriing and stuff on the dodge's i build chevy's not dodges lol so yeah more info would be good thanks for what you already have told me
Old Nov 5, 2009 | 07:43 AM
zman17's Avatar
zman17
It's a rectangular plastic box on the side(towards the driver side of the heat/ac unit under the dash. Maybe someone with a later model than mine can get a pic of it for you.
Old Nov 5, 2009 | 08:06 AM
95RAM360's Avatar
95RAM360
ill try getting a pic up...give me a few hours, im going to do my other shackle today anyways, and ill snap you a pic while im out there
Old Nov 5, 2009 | 08:51 AM
zman17's Avatar
zman17
You have a cable! That won't help him.
Old Nov 5, 2009 | 10:20 AM
95RAM360's Avatar
95RAM360
...i thought when you said later models...it meant my truck...i havent dug deep in heating/cooling systems yet
