brake light and cruise control
Old Nov 4, 2009 | 01:45 AM
reevesmb's Avatar
reevesmb
Default brake light and cruise control
2 issues first the center red brake light comes on after driving above 20 miles an hour, second cant find were the fuse or fuses are for the cruise control, the cruise light does not come on in the dash, assuming it is a fuse or relay. 1999 2500 4x4 5.9 ltr
thanks for your help
Mike
Old Nov 4, 2009 | 07:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Welcome to DF, You might get more help if you let us know what year it is.
Old Nov 4, 2009 | 02:29 PM
reevesmb's Avatar
reevesmb
i guess that would be helpfull info 1999 2500 4x4 Auto trans
Old Nov 4, 2009 | 03:17 PM
zman17's Avatar
zman17
Could be a number of things, but the CC is controlled by vacuum (so no relay or fuse IIRC). So check all the vac lines, and under the battery tray is the one(s) for the CC. The CC module/servo is under the tray too, so check for cracks in the housing. Also the brake light switch on the brake pedal can be an issue as can the wires being broken in the steering column, especially if you have a tilt wheel. You can also try this.https://dodgeforum.com/forum/2nd-gen...h-r-and-r.html
