What did you randomly notice with your Ram recently.
Old Nov 6, 2009 | 08:41 PM
  #71
WScott1500's Avatar
WScott1500
Originally Posted by Miami_Son
True, but with cast wheels, density variances in the materials can cause them to have heavy and light spots. Not so much a problem with low and high spots because these wheels are turned to dimension on a precision milling machine, but the weight variances can cause balancing issues. Still, the quality of most aluminum wheels today probably makes this kind of balancing overkill. A good high-speed balance should be sufficient for our trucks. On a sports car with a light chassis and tuned suspension, this process may make more sense.
I am a factory authorized technician for Hunter equipment. The idea behind "RoadForce" is to see how round the tire/wheel assembly actually rolls with a load on it (simulated vehicle weight). You are correct that many cast wheels have little problem with low and high spots. Factory wheels are almost always better than any but the most expensive aftermarket wheels. The wheel is rarely a problem (unless it has taken a heavy blow), but the variation of sidewall stiffness in tires is pretty amazing. The most uniform tires get sorted out for use on new vehicles and the rest get sent to tire dealers. Sometimes there is enough variation in the wheel to forcematch and cancel out the variation in the tire and sometimes not.
I agree that for the most part truck suspensions are not as sensitive to the variation in sidewall stiffness, but some of the larger, more aggressive tires used on 4x4's have substantial uniformity problems. Many would be amazed at the difference in ride quality after being forcematched.
For those who would like more info on this process you can read about it at www.GSP9700.com . There is also a tab labeled Locate A GSP9700 to find a shop near you that has this equipment.
Old Nov 7, 2009 | 02:05 AM
  #72
JackJ's Avatar
JackJ
Originally Posted by 95MaroonMonster
wow, man thats not good, when you say flight line, im guessing the deck on a carrier, if so, whats it like when of those F18 is catapulted, gotta be sweet to see in person
Never been to sea, the Hornet command I was with was Advisory, The nuts and bolt of that means that we played the bad guys to train the new guys air to air combat.
Not going the the carrier is one of my regrets after leaving the fighters, but it was not by my choice. The one time we were supposed to go to the boat Hurricane Katrina came and wrecked our plans. Hopefully I can go back to fighters and get some sea time under my belt.
Old Nov 7, 2009 | 10:19 AM
  #73
Sheriff420's Avatar
Sheriff420
Originally Posted by JackJ
My hearing is already shot, 3.5 years of 14-18 hour days on a flight line with up to 12 F/A-18's turning and another 2 years of C-130's will really screw up you hearing. I have failed my last two hearing tests and just recently my left ear has begun to randomly ring.
I'm only 25, and half deaf.
you sound like a friend of mine. he was FDC for field artillery in the 82nd. Airborne for something like 8 years and has been to iraq twice and he has a constant ringing in his ears, he's 29 now. he said that he hears it all the time. he's a drill sergeant now so at least he shouldn't do any more damage to his ears.
