Aux. Back Up Lights
Old Nov 4, 2009 | 07:59 PM
PurplDodge's Avatar
PurplDodge
Well ****! YOu got the older PDC. 99-01 trucks had a toatly different PDC with different relays. Plus you got much more room w/o the ABS acuator sitting next to the PDC.
Old Nov 4, 2009 | 08:51 PM
el_oso's Avatar
el_oso
I was going to say he has a hell of a lot more room than I do.
Purple, could you go back and clear up your original solution for me a bit?
Old Aug 27, 2011 | 08:42 PM
scot plaisance's Avatar
scot plaisance
can you help me find the circuit breaker for power window in a 1999 durango?
Old Aug 27, 2011 | 10:05 PM
If it is anything like the trucks, I do believe it is in the fuse block on the drivers side of the dash. Should be a guide as to what goes where on the cover.
Old Aug 28, 2011 | 11:26 AM
newman1367's Avatar
newman1367
You want the relay as close as possible to the lights. That's why I put my relay inside the drivers side brake light housing. It's away from the weather and as a bonus, the back up light wire is right there! Have had the lights on there for years and no problems.
