97 ram trans problem when warms up ??
my truck stopped up shifting , so I changed govener soluniod and transducer + filter .
took it for a ride and drove fine till it warmed up ,stopped up shifting again
let sit ,shifted fine till it got warm ?
any ideas ? and my abs light is on
+1 checking while in park, you get an inacurate reading. i noticed that (before i knew to check in neutral) when i checked it in park it was full. then found i have to check while in neutral, and found i was 2 1/2 quarts low. So Neutral is the way to get the reading
