No shocks???
Old Nov 6, 2009 | 05:16 AM
olyelr's Avatar
olyelr
Originally Posted by meanwhitemopar
you dont need to remove the springs, but it helps, if there is no shocks right now, they come out easy anyway...
Actually, you couldn't possibly install the shocks with the coils out... well, you could, but you couldn't put the coils back on once you were done
Old Nov 6, 2009 | 06:52 AM
dz302469's Avatar
dz302469
Originally Posted by dakotas ram
does it look like the front may be lifted?
It doesn't appear to be lifted.
Old Nov 6, 2009 | 06:54 AM
dz302469's Avatar
dz302469
Originally Posted by dodge15004x45.9
Well if you don't have shocks in there you are lucky none of the coil springs came out. You really need to look at stuff a lot better!
The shocks don't have anything to do with "holding" the coils in there. They are compressed and then placed between the control arms.
Old Nov 6, 2009 | 07:16 AM
95RAM360's Avatar
95RAM360
you may have to buy new bolts too. thats a dealer part i believe, which means its going to be like 20 bucks a bolt
Old Nov 6, 2009 | 07:35 AM
meanwhitemopar's Avatar
meanwhitemopar
yea you have to, but some people just lift the truck, leave teh axle in place, and set the shock down in, so thats what i ment, misunderstood...
Old Nov 6, 2009 | 07:39 AM
meanwhitemopar
the spring doesnt hold anything in, this it true, but the axle has nothing to stop it from dropping a far distance as of now, so if you were to hit a heck of a bump, you could "drop" a coil spring out, normally the shocks act as the limiting straps and it stops the axels drop amount.. so to explane another way, no shocks= no limit to the drop amount odf the axle. except maybe the tracbar...
Old Nov 6, 2009 | 08:00 AM
Sheriff420's Avatar
Sheriff420
the track bar limits the axle drop. i know because i had to disconnect mine to put my coil spacers in.
Old Nov 6, 2009 | 08:22 AM
dakotas ram's Avatar
dakotas ram
the shock should not bottom out. it doesnt act as a limiting strap.....
Old Nov 6, 2009 | 08:32 AM
95RAM360's Avatar
95RAM360
all in all its an easy job, took me about anhour each side. but you dont have to wory about taking anything out, so you could have all of it done within an hour
Old Nov 6, 2009 | 01:00 PM
Miami_Son's Avatar
Miami_Son
Sorry man, but this is just wrong. The shocks are not a structural part. If you were to hit the limit of travel on a shock it would tear it apart or damage the mountings. They are not strong enough to stop the travel of a 1000# axle. Axle travel is normally controlled by the control arms and the track bar. Under normal operation there is no way to extend the travel enough for a spring to pop out because you would reach the mechanical limit before the spring extension limit. That's why springs have to be compressed to be installed unless you disconnect the track bar to allow the axle to drop beyond its mechanical limit of travel.
