No shocks???
Old Nov 5, 2009 | 07:43 PM
dz302469's Avatar
dz302469
Default No shocks???
So I'm under the front checking out the suspension and changing the oil when I notice.....no shocks on the front of my truck. (Just bought it used this week.
I assume they go up through the coils as on most cars/trucks. It doesn't bounce around or show any signs of no shocks, but there are none there.
Any ideas? I'm thinking immediately get some new ones and get them mounted.
Thanks.
Old Nov 5, 2009 | 07:57 PM
95RAM360's Avatar
95RAM360
yea the are very easy to put in. they are just shock absorbers to take some of the tension off the spring. you can get them for pretty cheap i think they start at 21.99 each at a local auo parts store. but you get what you pay for. and there is no need to remove the spring when doing the job. it will take less than 2 hours if you have basic mechanical knowledge
Old Nov 5, 2009 | 08:29 PM
dz302469's Avatar
dz302469
So you're saying the trucks don't necessarily come with them? I've never heard of that before.
Thanks. I can put them in....no problem.
Old Nov 5, 2009 | 08:30 PM
95RAM360's Avatar
95RAM360
no im not saying they dont come with them, they are supposed to have them. im saying that its not really hurting it not having it right now.
Old Nov 5, 2009 | 08:31 PM
meanwhitemopar's Avatar
meanwhitemopar
they all come with shocks, how there is no shocks an the truck doesnt bounce, is wierd, can ya get a pic of it?
you dont need to remove the springs, but it helps, if there is no shocks right now, they come out easy anyway...
Old Nov 5, 2009 | 08:57 PM
dz302469's Avatar
dz302469
Ok, I misunderstood. I can't figure why there aren't any, but I'll never know the answer.
I'm going to put some on this weekend.
Old Nov 5, 2009 | 08:58 PM
Sheriff420's Avatar
Sheriff420
when i changed my shocks i gave the brush guard a push with them out and it bounced about 15-20 times. i don't see how you have no bounce.
when you put them in, the bottom bolt takes 100ft-lbs and loc tite. and it is 21mm.
can't remember the torque for the tower bolts but i think its around 35 ft-lbs.
Old Nov 5, 2009 | 08:59 PM
dz302469's Avatar
dz302469
I'll take pics before I start the job. I did the bounce test and it doesn't bounce a lot. However, the springs are pretty stiff and I can't push the truck down that far. Anyways, I'm going to install some this weekend.
Old Nov 6, 2009 | 12:53 AM
dakotas ram's Avatar
dakotas ram
does it look like the front may be lifted?
Old Nov 6, 2009 | 12:57 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Well if you don't have shocks in there you are lucky none of the coil springs came out. You really need to look at stuff a lot better!
