tip to adjust power band
Old Jan 19, 2010 | 12:12 AM
  #21
Ram_Me's Avatar
Ram_Me
Originally Posted by dodgeram07
now mod your tb!!! and its free!!!!!!
For free? How??
Old Jan 19, 2010 | 01:44 AM
  #22
Dakine69302's Avatar
Dakine69302
ya...wha'ts it mean to mod your tb?
Old Jan 19, 2010 | 03:10 AM
  #23
Big_Red_01's Avatar
Big_Red_01
thw mod that my buddy did was cutting off the extra metal around the ports and rounding the edges for smoother air flow... havent tried
Old Jan 19, 2010 | 05:39 AM
  #24
meanwhitemopar's Avatar
meanwhitemopar
take your neg battery cable off, then unplug the ecm, the three plugs on the passengers side firewall... leave it for about 30 mins, go back, plug the ecm back in, neg hook up, and try again
Old Jan 19, 2010 | 06:41 AM
  #25
PurplDodge's Avatar
PurplDodge
Originally Posted by Big_Red_01
i dont even know what the pcm is but it has probably 30 min idle time and 20 min drive time
Huh?
Old Jan 19, 2010 | 07:03 AM
  #26
Big_Red_01's Avatar
Big_Red_01
sence it started acting up
Old Jan 19, 2010 | 06:58 PM
  #27
Ram_Me's Avatar
Ram_Me
That seems hardly worth the effort for what little gain you would see, if any.
Old Jan 19, 2010 | 09:29 PM
  #28
PurplDodge's Avatar
PurplDodge
Originally Posted by Ram_Me
For free? How??
Dodgeram07 did a write up on it a while ago.
Old Jan 20, 2010 | 01:01 PM
  #29
Green1500's Avatar
Green1500
You can try putting a resonator on the exhaust, this will give you more back pressure which will give back you low end. Downfall is will not be as loud. Drag cars set up their exhaust all the time to compensate for short drags and long drags, (low end and top end power). The more free flowing exhaust the higher topend.
Old Jan 20, 2010 | 02:01 PM
  #30
Augiedoggy's Avatar
Augiedoggy
the only way to do it and have it really effect anything is boring the openings to say 52mm and getting the larger butterflies to fill the larger throats... but again you need a better than stock flowing exhaust for this to help with power and not lose torque....better flowing herads are a big plus here too...
