Help Please window stuck
Old Nov 7, 2009 | 09:34 PM
hondarider's Avatar
hondarider
Default Help Please window stuck
My passenger window is stuck in the down position! What to check... But how do I get it up manually so I can drive for now? Thankss
Old Nov 7, 2009 | 09:44 PM
Weldor's Avatar
Weldor
This happens to me a lot just on the drivers side. Mine would always fall off the track, I had to take the door panel off and manually feed it up with my hands alittle bit at a time. This is for manual windows, if you have power I'm not to sure.
Old Nov 7, 2009 | 09:53 PM
hondarider's Avatar
hondarider
I have power
Old Nov 7, 2009 | 10:04 PM
WaynesWorld's Avatar
WaynesWorld
Your guna have to take off the door panel and unbolt the glass to window regulator. Move the glass all the way up and use tape to keep it there until you find a fix.
Could be your switch, or motor. Sometimes you get lucky and can tap the motor with a hammer and clean out that pesky dead spot
Old Nov 7, 2009 | 10:12 PM
WaynesWorld
check the switch with a test light or volt meter
Old Nov 7, 2009 | 10:21 PM
xray99's Avatar
xray99
First thing to do would be check the fuses, maybe you popped one ?
If that don't work theres no way to get it up without taking the panel off.
Hopefully it will be a wiring/switch issue, if not it looks like its time for a new motor.
Old Nov 7, 2009 | 10:22 PM
hondarider's Avatar
hondarider
Yea thats what Im going to do. Now here this. Before it went out, i could control it perfectly with the drivers side switch but on the passenger only up not down...
Old Nov 7, 2009 | 10:24 PM
xray99's Avatar
xray99
Sounds good, probably a switch issue then, or a short on the passenger side.
I'm pretty sure both windows are tied into the same fuse, so if one works its probably not that.
Old Nov 7, 2009 | 10:29 PM
WaynesWorld
if you cant hear the motor working (or trying to) then I'm guessing it is the switch (both drivers side and pass)
Maybe try unpluging the switch and use a jumper wire to bypass?
Old Nov 7, 2009 | 10:37 PM
crazzywolfie's Avatar
crazzywolfie
could be a bad wire between the door and the cab. its not too uncommon.
