ABS and BRAKE light still on?????
Old Nov 10, 2009 | 06:58 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by VEETEN
ZMAN I was just wondering if this was a common issue, I thought I was just lucky to have it break there.
Cause I got that special truck and I have that special luck happening too...LOL
It is a fairly common issue.
Old Nov 10, 2009 | 10:33 AM
bigtman07's Avatar
bigtman07
So its the rubber part of the brake line and not the steel line that I need to check for leaks?
Old Nov 10, 2009 | 10:43 AM
zman17's Avatar
zman17
Both, but it's the steel line that rots out.
Old Nov 10, 2009 | 10:50 AM
bigtman07's Avatar
bigtman07
Ok then. Well sounds like another weekend project. So run tank to about empty. That's not hard. tehe Then drop the tank and look for pinhole leaks. Should I have the misses push on the pedal to make sure or could that make it worse?
Old Nov 10, 2009 | 11:36 AM
zman17's Avatar
zman17
Can't hurt to have her do that. Look at all the lines everywhere when she does that. You also might be able to see up on top of the tank with a flashlight. If you can't, just lower it enough to see, this way you don't have to deal with disconnecting the fuel pump fittings.
Old Nov 10, 2009 | 01:55 PM
bigtman07's Avatar
bigtman07
Yea good idea. I heard the connectors are a pain. Hopefully we will have another nice weekend and I won't have to bother my buddy with the lift and heated garage.
Old Nov 11, 2009 | 12:33 PM
EHS22's Avatar
EHS22
I have that same problem with my 97 ram 1500, the lights stay on all the time and sometimes they come off and on randomly i have replaced the same things you have and it dosent fix it!
Old Nov 11, 2009 | 12:42 PM
Sheriff420's Avatar
Sheriff420
on trucks that are exposed to road or beach salt.
Old Nov 11, 2009 | 01:09 PM
bigtman07's Avatar
bigtman07
Well we definitly get enough salt up here. Used every winter.
Old Nov 11, 2009 | 01:15 PM
zman17's Avatar
zman17
You may have a connector issue.
Hence the "fairly common" quote. Of course looking at it that way, it's a major problem. LOL
