A/C Compressor - running while not using AC?
Old Nov 9, 2009 | 04:02 PM
omanalansan's Avatar
omanalansan
Default A/C Compressor - running while not using AC?
I just noticed this morning that my compressor kicks on for 3-4 secs. Is it suppose to kick on even when i'm not using the AC? It was cold this morning Northern VA....
Many thanks in advance
Old Nov 9, 2009 | 04:34 PM
95RAM360's Avatar
95RAM360
i have read a number of posts on this same topic. and the results are everyone is just running it like that.
Old Nov 9, 2009 | 04:37 PM
omanalansan
ok thanks 95RAM360..
Old Nov 9, 2009 | 05:59 PM
95RAM360's Avatar
95RAM360
im sorry i couldnt be of more help. im basically saying its not anything to really worry about.
Old Nov 9, 2009 | 06:07 PM
coreyt's Avatar
coreyt
The AC system runs cycles when you have the defrost on to help remove the moisture from the air in the cab.
Old Nov 9, 2009 | 10:00 PM
oiler's Avatar
oiler
Mine cycles with the heater on.
Old Nov 10, 2009 | 06:52 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I just got done swapping motors in a 99 Ford Explorer, the AC cycles on that also, so It's not just a Dodge thing.
Old Nov 10, 2009 | 11:13 AM
omanalansan
thanks guys for the info, i believe i had my setting on defrost too.
Old Nov 10, 2009 | 09:23 PM
DODGEIT105's Avatar
DODGEIT105
Yes it is suppose to do that. The A/C has a filter dryer(Sometimes called an accumulator) in the line to remove moisture. It will run using the defroster to dry the air passing through it. It wil run in the heat mode to cycle the air some. Basically every position on the dial runs the compressor.
Old Nov 11, 2009 | 06:48 AM
olyelr's Avatar
olyelr
Every position except the "feet only" and "front dash only".
