Need Rear Door Linkage Rod Retainer Clips For Quad Cab
Old Nov 11, 2009 | 11:55 PM
Dizzydan02's Avatar
Dizzydan02
Default Need Rear Door Linkage Rod Retainer Clips For Quad Cab
Hello everyone, just purchased a '99 Ram 1500 4x4 SLT Laramie Quad Cab w/ 360.
I have looked everywhere (even used the search button on this site) and still can find what im looking for.
I need some linkage rod retainer clips for both of the rear-doors of my quad cab. I am unable to open the doors from either inside or outside door handles. I have to take off the rear door panel and pull the linkage rods to get the doors open.
Does anyone know a site that sells these or a fix? (doesnt seem like a very good design) The closest Chrysler dealer to me is about 50 miles away so hopefully I can find some online.
Thanks
Old Nov 12, 2009 | 01:55 AM
J415's Avatar
J415
Where exactly have you looked? The stealership should have that part.
Old Nov 12, 2009 | 07:25 AM
moparama's Avatar
moparama
are u sure its the linkage rod clips i had same prob but the bad thing was the lower latch was froze. i ended up having a buddy hold the handle while i mule kicked the sob from inside the truck. then when i removed the inside panel after i got door open i broken the cable for the inside handle and cant seem to locate them other then the dealer
Old Nov 12, 2009 | 10:19 AM
Dizzydan02's Avatar
Dizzydan02
Ive looked everywhere online for the rod clips and ive looked for people that have the same problem as me and cant find anything. Hopefully I dont have to drive 50 miles to the dealer just to get the clips.
The latches arent frozen on mine, I can pull up on the lower rod and down on the upper rod from the inside of the doors and the doors will open easily.
Old Nov 13, 2009 | 08:43 PM
Dizzydan02's Avatar
Dizzydan02
Well I pinched the rod retainer clips together and snapped the rods back in place for a temporary fix. Then welded the retainer clips to the rods and wa-lah. Better than the factory made them.
Old Nov 13, 2009 | 09:40 PM
J415's Avatar
J415
That's the DF way!!!
