Engine won't start
Old Nov 18, 2009 | 11:29 AM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Bourquin's
Z-MAN, your a life saver.....unsrewed the o2 sensor and bam, fired right up, dont know why i didnt think of it, had same problem with another truck of mine few years back...thank all of you for your help, guess its time to cut out cat and install "test pipe" or might just get new cat yet haven't decided. Thanks guys
Now you need to fix the plenum. Don't install a new cat, without fixing it.
Old Nov 18, 2009 | 11:30 AM
  #22
Bourquin's's Avatar
Bourquin's
yeah i got all parts i swapped out, she needed a good tune-up anyway....and i need coil for my wifes jeep with 318, so i'll just put one i took off onto it, looks the same....she wont know difference.
Old Nov 18, 2009 | 11:31 AM
  #23
Bourquin's's Avatar
Bourquin's
the plenum? you mean replace gasket? did that already about 6 months ago.
Old Nov 18, 2009 | 11:46 AM
  #24
zman17's Avatar
zman17
You replaced the plate as well with a Hughes or APS right? If you didn't, the gasket replacement only will blow again.
Old Nov 18, 2009 | 01:09 PM
  #25
Bourquin's's Avatar
Bourquin's
no all i did was replace gasket, where would be cheapest place to find plate?
Old Nov 18, 2009 | 01:11 PM
  #26
zman17's Avatar
zman17
Hughesengines.com http://www.hughesengines.com/Index/p...2&partid=22220
Old Nov 18, 2009 | 01:18 PM
  #27
Gary-L's Avatar
Gary-L
Veteran: Navy
I might go "the extra step" by removing the center divider plate from my intake and then having the replacement aluminum pan welded to the intake. No more gasket worries.
