Paint removal
Old 11-18-2009 | 12:55 PM
RSDodgelover's Avatar
RSDodgelover
Default Paint removal
I recently followed a line striping crew and made the mistake of getting into the fresh white line paint. Consequently I now have a LOT of splatter under my truck as well as on my step bars and the side of my truck. I am sure that this happens all the time but am not sure what works best to remove it. Any suggestions? Thanks
Old 11-18-2009 | 01:09 PM
95RAM360's Avatar
95RAM360
very fine sandpaper, and you will probably have to get areas repainted/clearcoated
Old 11-18-2009 | 01:11 PM
RSDodgelover
Not the answer I was looking for. Any other options?
Old 11-18-2009 | 01:14 PM
95RAM360's Avatar
95RAM360
any chamical u use to take off the splattered paint, is going to affect the paint on your truck. Your going to have to get areas repainted, theres not vey many options in this matter.
Go to your deler and get the paint code and have them order you paint. i got 3 5oz cans of paint for my truck, its the exact color, and for all 3 it was 27 bucks. spray it on, then clearcoat, you wont know the difference/
Old 11-18-2009 | 02:50 PM
dakotas ram's Avatar
dakotas ram
try rubbing compound or googone, since its alot fresher than your paint it should come off fairly easy
Old 11-18-2009 | 02:55 PM
95RAM360's Avatar
95RAM360
well good luck with it anyways. post some pics of before/after
Old 11-18-2009 | 06:06 PM
Augiedoggy's Avatar
Augiedoggy
if its just splattered paint it will come off easy with cleaner wax/polish or rubbing compound. ....if its cured good or a larger amount paint thinner mineral spirits or lastly acatone....just be sure to wipe fast and hard and follow with a clean damp rag to get it off so it doesnt sit on ther finish (same way you would remove vandelism or pfresh paint overspray..the longer you wait the harder it is to get off) your auto paint should be cured and stay put and be uneffected unless its a rattlecan job....then its tougher to get one off without hurting the other.
Old 11-18-2009 | 07:43 PM
redheadhunter21's Avatar
redheadhunter21
Depending on how long its been sitting on the paint a plastic scraper could pop it off then wax your paint shouldnt know it was there
Old 11-18-2009 | 07:46 PM
dhvaughan's Avatar
dhvaughan
i would try paste wax first.
rubbing compound next. rub GENTLY.
mineral spirits third.
...i wouldn't use acetone, sandpaper, or anything course.
Old 11-18-2009 | 08:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can also try this. Buy some mcquires detail spray and a clay bar. Keep the cars paint lubed with the spray and rub with the claybar.
