front mount hitch
Old 02-09-2010, 11:25 AM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
I finally put the hitch on my truck. I decided to just weld it onto the crossmember. I cut both ends off the hitch so i could mount it flush with the frame. The receiver tube had a 1/8" plate on top of it, so I welded a 1/8" plate all the way across so it would be completely flat on top, then I welded it all the way around where the hitch touches the crossmember. I still need to cut a hole in the air dam and bend my bar on the brush guard back down so i can put the shackle in the hitch. It is nice because the hitch lines up perfectly with the air dam and it is below the license plate bracket.
I can get more pictures if anyone wants them.
Also, FYI, welding sucks when you're laying on your side and putting down a 4' bead that you really goober on to make sure it'll hold.
I gotta throw this picture in there because welding pictures are awesome.
  #22
Old 02-09-2010, 12:51 PM
iwhitne's Avatar
iwhitne
iwhitne is offline
kick *** man!!
  #23
Old 02-10-2010, 05:02 PM
Sheriff420's Avatar
Sheriff420
i took a couple more pictures. remember that i hardly ever weld and i was in an awkward position when trying to weld it without having the slag dribble down on my arm and burn the **** outta me.
  #24
Old 02-12-2010, 01:14 AM
Sheriff420's Avatar
Sheriff420
got a towing loop for it today.
  #25
Old 02-12-2010, 02:04 AM
hirschy's Avatar
hirschy
hirschy is offline
Looks sweet.
Jeff
  #26
Old 02-12-2010, 03:54 PM
notanexit7's Avatar
notanexit7
notanexit7 is offline
Draw-tite makes one. I'm getting one once I get my leveling kit done.
  #27
Old 02-12-2010, 04:01 PM
yakkier's Avatar
yakkier
yakkier is offline
awesome work man looks great
  #28
Old 02-12-2010, 04:03 PM
Sheriff420's Avatar
Sheriff420
that draw tite hitch hangs down too low for me.
  #29
Old 02-12-2010, 04:27 PM
notanexit7's Avatar
notanexit7
how low we talkin?
  #30
Old 02-12-2010, 04:52 PM
Sheriff420's Avatar
Sheriff420
a good 2.5-3". i prefer having the hitch above the bottom of the air dam, flush with the bottom of the bumper.
it is also only rated for 300lb tounge weight and 9000 lb line pull.
Quick Reply: front mount hitch
