What is wrong with my doors?
Old Nov 19, 2009 | 11:39 AM
Pysiek's Avatar
Pysiek
Default What is wrong with my doors?
My 98 extended cab have problem with the small doors on the back. When I pull the handle they're unlocked but I can't open them. What should I do to remove them and check what is wrong?
Old Nov 19, 2009 | 12:43 PM
RedRigRon's Avatar
RedRigRon
Lube the hinges, locks, lube everything that moves. If that don't work replacement of internal parts maybe required.
Old Nov 19, 2009 | 02:09 PM
meanwhitemopar's Avatar
meanwhitemopar
my passengers side door does the same thing... pull the handle, inside or outside, and the door does nothing, it is missing a few parts in the door and i didnt know it till i for some reason went to that door... and it no worky
Old Nov 19, 2009 | 02:14 PM
95RAM360's Avatar
95RAM360
sounds like the meal piece that is connected to the handle that releases the latch came undone/broke
Old Nov 19, 2009 | 02:41 PM
Miami_Son's Avatar
Miami_Son
This is a common problem and there are a number of existing threads about it that can be found by doing a search.
