high beams still wont turn off
Old Nov 22, 2009 | 04:04 PM
PlrBrr's Avatar
PlrBrr
Default high beams still wont turn off
i just got back into town after being deployed a year. i have been having problems with my high beams. there not on, but the indicator is. My fog lights wont turn on either. i just replaced the multi-function switch in the steering column but nothing still having problems any ideas? do i need to start chasing wires i am lost. thanks
Old Nov 22, 2009 | 04:19 PM
aim4squirrels's Avatar
aim4squirrels
do you have aftermarket lights?
Old Nov 22, 2009 | 04:24 PM
PlrBrr's Avatar
PlrBrr
no everything is stock. i dont eally know how or what happened my wife was driving it while i was over seas
Old Nov 22, 2009 | 06:23 PM
dsertdog56's Avatar
dsertdog56
Perhaps your truck is from Canada?
If so, you have daytime driving lights. There's a module under your power panel box/ABS crap (inner fender) thats black in color.
Pull the plug out of it, and your issues should end. Don't worry your lights will still work. The DLR supplies voltage to your front lamps when you drive during the day.
Old Nov 22, 2009 | 07:14 PM
Cheat's Avatar
Cheat
Or it could be the whole light control thing in the dash?
Its burnt out on me like 3 times.
Old Nov 23, 2009 | 03:31 PM
PlrBrr's Avatar
PlrBrr
no not from Canada and no daytime driving lights what light console in the dash can you be a bit more descriptive cheat thanks are you talking about the switch to turn the lights on and off?
Old Nov 24, 2009 | 05:06 AM
[roger]'s Avatar
[roger]
9005 or 9007 in lowbeams
Old Nov 24, 2009 | 02:17 PM
PlrBrr's Avatar
PlrBrr
just replaced the headlight switch on the dash looks like i will be running wires trying to figure it out. high beam indicator still work turn off. i guess while i was gone my wife replaced my lights and the light wiggled out and melted the head light casing so i need to replace that i am thinking about some bright lights just beacuse it tends to be dark all but 6 hours out of the day.
Old Nov 24, 2009 | 10:24 PM
skostur79's Avatar
skostur79
x2 im having trouble with mine too
i have the quad headlamps , all 4 stuck on , high beam indcator is dim
i just got done pulling to front harness apart to check the splices
its ok ,
if i unplug my right low beam all returns normal
ill try some more tomarrow if i can it ill post my fix
Old Nov 25, 2009 | 01:59 AM
PlrBrr's Avatar
PlrBrr
i was pulling playing with my lights and i found that when i pull drivers side light (melted housing) my problem goes away plug it back in problem comes back no change in pulling passengers side. but when do a controlled exchange and switch them out for each other and i pull the drivers side there is no change i still have the problem but when i pull the passenger side i loose the problem i think i have found the problem an its in the light. i have 9004 in there as my lights
