Throttle Body
Old Nov 23, 2009 | 12:59 AM
JohnnyRebs360's Avatar
JohnnyRebs360
Default Throttle Body
I just brought a new throttle body for my truck. It is a 50mm bore. That has been bored and polished. The top has been angled. I like to find somebody who has the 50mm and/or 52/53mm throttle body.
Old Nov 23, 2009 | 01:12 AM
J415's Avatar
J415
For...? Are you looking for a date...
Old Nov 23, 2009 | 01:15 AM
JohnnyRebs360
No smarty, Like see if anybody got the same setup.
Old Nov 23, 2009 | 01:18 AM
J415's Avatar
J415
Mine is bored 50 mm threw. Not a fastman, just a home brew. BTW, I was joking...obviously.
Old Nov 23, 2009 | 02:00 AM
JohnnyRebs360
Hey everybody needs a sense of humor.
Mine is also a home brew that I got from ebay.
I was told by this guy and the fastman that the 52 is for modified engines, And the 50mm would be better in my case, due to the large tires. I hope it makes a difference. Can not wait to install it.
Old Nov 23, 2009 | 02:55 AM
J415's Avatar
J415
Yup, you'll here the same thing around here also.
Old Nov 23, 2009 | 10:21 AM
Sheriff420's Avatar
Sheriff420
50mm is ideal for a 5.2l
52mm is ideal for a 5.9l
when you have a majorly modified motor you will want a bigger bore and that is when you have the fastman do a custom bore for you.
my 50mm is home brew also (20$ for it and the machining just cost time) but i haven't driven the truck enough to relearn the idle yet. it is still idling around 1000 rpm. but i've only driven it about 30 miles since the install.
